Older UI is a master card/tag, a 12 digit keyboard with 3 LED's above it, and a manual that is 30 pages long with 25 being devoted to install and add tags. Delete requires you to have a book with the tag numbers in it so as to delete, and a convoluted keyboard operation to delete.
Then again i deal with gate motors a little, where the UI is a button and a LED where you count flashes and press the button in time with the flashes. Newer ones have a LCD display and are a breeze to set up, but still you find it hard to delete remotes, so I use another receiver ( not the integrated one) which actually can delete individual remotes easily. As well it allows me to back up the remote list as well, which has come in useful as well.
