Author Topic: EEVblog #533 - LED Fluoro Tube Teardown  (Read 21814 times)
Offline EEVblogTopic starter
« on: October 09, 2013, 11:01:47 am »
Offline HackedFridgeMagnet
Re: EEVblog #533 - LED Fluoro Tube Teardown
« Reply #1 on: October 09, 2013, 01:55:44 pm »
Just wondering what the 10ohm input resistor is for, its in the nxp? datasheet schematic. Also why did they put the fuse after the MOV.
The data sheet for the light said >0.9 power factor, that seems a bit of a stretch considering the lack of PFC correction.
edit: apparently it is for current inrush. By my calcs it will use 0.8 of a watt, which does effect the efficiency a bit.
« Last Edit: October 09, 2013, 11:10:59 pm by HackedFridgeMagnet »
Offline madworm
« Reply #2 on: October 09, 2013, 05:40:45 pm »
Those tiny LEDs are pretty amazing. I've used similar ones made by Nichia ( NSSL157AT / NSSW157AT ) and was afraid to overheat them, but it didn't happen. I made the effort to add copper-pour heatsinks on both sides of the PCB, which turned out to be overkill. The single-sided solution is very sufficient in terms of cooling.
Offline cengland0
« Reply #3 on: October 09, 2013, 06:21:08 pm »
What was that you said about being surprised there wasn't a resistor between each row of parallel LED's?  Is there a problem putting LEDs in a parallel/series configuration like this without resistors?
So if I wanted to do have a string of LEDs and the supply voltage didn't allow them all to be in series, I thought I could do exactly what those fluro tubes did and have some in series and then put those in parallel.  Didn't know there should be a resistor between each set of them.
Sorry for the newbie question but I'm dying to know.
Offline madworm
« Reply #4 on: October 09, 2013, 06:33:14 pm »
Yes and no ;-)
Current regulation for each string is safer, but more expensive. If for some reason one LED blows in a paralleled string and fails shorted, more current will pass through that string. This will probably cause more LEDs to fail.
This appnote discusses calculation for current-sharing resistors for paralleled LED strings.
http://www.ti.com/lit/an/slva325/slva325.pdf
Offline bktemp
« Reply #5 on: October 09, 2013, 06:42:37 pm »
LEDs (especially when not from the same batch or even different types) have a slightly different voltage drop. If you connect them in parallel the LED with the lowest voltage drop draws a higher current. Due to the higher current, the LED gets warmer than the other LED which reduces the forward voltage and further increses the current. To avoid this, a resistor is added.
These resistors are often omitted because they waste power, add additional costs and they are not always neccessary: The LEDs mounted on such boards come from the same reel, so they probably have a similiar forward voltage (you can get LEDs sorted by their forward voltage). White (and blue) LEDs also have a higher internal resistance than green and red ones.
Offline FrankBuss
    • Frank Buss
« Reply #6 on: October 09, 2013, 06:47:00 pm »
Dave, just in case if you want to know how it is pronounced right :) at 0:10:
But I guess the company is not as big as for example Osram, I never heard of it.
Offline smashIt
« Reply #7 on: October 09, 2013, 06:56:37 pm »
dave, they probably underpower those leds to keep heat-dissipation under control
even if they could get all the heat from the led into de aluminium-profile it would still be inside a plastik tube  inside a case  mounted under the ceiling
no chance of getting rid of the heat without active cooling
Offline cengland0
« Reply #8 on: October 09, 2013, 07:16:02 pm »
Thank you for that explanation.
So, since some of the LEDs are in series, they must all take the same current and that's understandable and okay.  But, if you hook them up in parallel, one set may have an internal resistance higher or lower than the others and will then consume more or less current than the other strips.  I get that now.  So how will adding a resistor help?  Wouldn't you need to customize that resistor to be an exact and customized value for each Fluro tube that you create?  You would measure the internal resistance of each strip and then put custom resistors in series to each strip to make them all the same.
If, in your manufacturing process, you just put the same value resistor on all four strips, some strips may still consume more current because of the total resistance after considering the LEDs plus the resistor will still be different.
Offline madworm
« Reply #9 on: October 09, 2013, 07:41:56 pm »
Again, I suggest to read the appnote. It is not difficult to understand.
Or in other words: RTFM.
Offline free_electron
    • SiliconValleyGarage
« Reply #10 on: October 09, 2013, 11:09:44 pm »
true and not true.
LEd's are binned according to color temperature during test. the are also very tihgtl controlled in terms of Vf.
If you go to the local store for 20 led's you have no idea where they come from. you may have 5 from this and 9 from that.. depending on wheat the guy has in his little drawer.
Users lik Mueller buy led's in bulk. these are tightly controlled and their specs ARE known. you can bet money that mueller went to their le dmanufacturer and have filtering done on tolerances... so in these designs you can get away without the balancing resistors because you have supply chain control. and any resistor saved means more profit for them.
as a hobbyist : can't do that.. put resistors.
Offline owiecc
    • Google scholar profile
« Reply #11 on: October 09, 2013, 11:13:52 pm »
LEDs may be underpowered because of three reasons:
1. As smashIt said, keeping thermal under control.
2. Current sharing. If they would be supplied with 240mA (60mA*4) then they need perfect current sharing not to go over 60mA. If current sharing is not ideal then they must limit the current in the string that gets the max current. Assumption then is that one string gets 60mA and other strings get less than 60mA. Then, in total, you need to supply less than 240mA. I guess if they know the forward voltage distribution in a batch they can estimate what is the probability of getting a decent current sharing. Maybe its a good idea for a new massive number of measurements video :)
3. Lower current = more lm/W.
Offline victor
  • Boy who writes code and take things apart
    • vitim.us
« Reply #12 on: October 10, 2013, 12:17:02 am »
I commented on the previous video, that I wonder what difference the diffuser make, I think from the ceiling is far enough to get the light spread and not bright spots on your desk.
The plastic tubing is mostly to user protection since it's not isolated.
your body is limited, but not your mind
Offline owiecc
« Reply #13 on: October 10, 2013, 07:03:06 am »
The diffuser is there to lower the maximum luminous emittance (lumens emitted per area). Lowering this value makes the light source easier on the eyes when you look at it directly. You don't have a number of very bright spots but a big, reasonably bright, surface. This is why OLED panels may be a win in the future. They don't require specific optics and diffusers to do just that.
Offline DutchGert
« Reply #14 on: October 10, 2013, 07:10:18 am »
I thought they would be using something like IMS PCB's (http://en.wikipedia.org/wiki/Insulated_metal_substrate#Insulated_metal_substrate) for applications like this but thats perhaps more expensive than making a aluminium 'cooling clip' like they did now.
Offline innot
« Reply #15 on: October 10, 2013, 07:22:39 pm »
Hi Dave,
while I appreciate your fondness for German engineering, I think that the only german part of this LED tube is the umlaut in the name.
Müller Light (which I never heard of before) seems to be mostly a reseller and distributor. I could not find any indication on their website that they do any electrical engineering at all. Or as they write themselves: "our quality standards are 'Made in Germany'". Just the standards, nothing else.
In addition to the use of some cloned chip, the use of this ugly serif font for the silkscreen (which the Chinese seem to be so fond of that they use it everywhere) indicates to me that this LED tube has not seen any german engineering and is just another "One-Hung-Low" product, including the LEDs which I doubt to be real Luxeons.
But then again ALDI is not the place where you would expect to find high quality stuff -- just reasonable quality at competitive prices.
Cheers,
Thomas
Offline david77
« Reply #16 on: October 11, 2013, 04:53:49 am »
Probably true.
I've had very bad experience with Müller Licht incandescent and halogen bulbs. Didn't last more than 3 months and many of them were already broken when delivered. Cheapest crap you can think of.
Offline nowlan
« Reply #17 on: October 11, 2013, 12:15:51 pm »
My friend said his work had to gut all the old light fixtures when they changed over to led tubes recently. I couldnt understand why they didnt put smarts in the tube (like we just saw). What would electricians be doing if not simply swapping in new tubes?
Offline jolshefsky
    • Jason DoesItAll
« Reply #18 on: October 11, 2013, 07:05:00 pm »
Dave,
I too think you went pretty soft on the design. The meter-long mains-level trace millimeters from the LEDs (called out in a text overlay on the video) and the use of a cheap brand of filter capacitors are two things you would have been much harder on had it been a cheap Chinese product. I would only go so far as to say the design passes the Australian safety requirements ... otherwise it's only marginally good.
May your deeds return to you tenfold.
Offline sync
« Reply #19 on: October 11, 2013, 09:19:44 pm »
I'm not sure if this is a problem. It's filtered and rectified mains. Will mains transients also occur on it? And the LEDs are not isolated from mains anyway.
Offline Brutte
« Reply #20 on: October 12, 2013, 06:14:10 pm »
(..)so in these designs you can get away without the balancing resistors because you have supply chain control. and any resistor saved means more profit for them.(..)
Hi. Here is how I see that problem from control theory perspective:
The terminal temperatures variation of these LEDs cannot be controlled with the use of tighter/more stringent tolerances. It is because of an internal property of the differential equation that describes the process. No matter how hard you try, the resolution of (linear) approximation of those (nonlinear in general) equations has an unstable element (with positive exponent).
A basic concept
That is - the tolerances control how much positive the exponent is but can never make exponent negative (and thus stable) so that the terminal temperatures are more and more even with time. Same applies to BJT transistors connected in parallel - if you do not provide some governor then eventually they die one by one.
Of course it is not that without some explicit control the difference of temperatures rises infinitely because some other phenomena also take part in that equation (like thermal coupling, limited temperature rise of the LED itself, copper tracks that have some resistance etc).
The fact is that the more variation in between LEDs terminal temperatures, the less efficient/competitive the design really is. Resistors are one of the most popular solutions because the attractive tradeoff in between losses and temperatures. Alternative designs could  connect LEDs in series or drive two strings with 50% PWM etc but the resistors are typically "be$t".
I suppose that one of the reasons for the poor temperature/current stabilization could be that the EU directive about energy efficiency requires that it is 18W/1700lm light source only for 10 minutes of testing and not during the marketed life of 30000h.
Offline NiHaoMike
    • Facebook Page
« Reply #21 on: October 12, 2013, 10:41:37 pm »
The existing ballast coil would act as a passive PFC. Combine that with what would normally be an undersized filter cap and the power factor can be pretty good.
Offline NickS
« Reply #22 on: October 13, 2013, 02:32:10 am »
Buying it through Aldi makes it pretty reasonable however.
Meets Australian standards and you can take it back for a full refund after 2 months for any reason makes up for not top notch quality.
And as Dave said, they will probably do the job quite well for quite some time.
Offline tzaphkiel
« Reply #23 on: October 17, 2013, 11:52:15 am »
Dave,
What about the RF interference and/or electrical interference it creates with comparison to old-style neon lights?
Would it be possible to investigate this?
Would it be thus better to light your lab with such lamps instead of the classic daylight neon tubes?
@see: http://www.signindustry.com/neon/articles/2004-02-16-RadioFrequency-RC-.php3 & http://www.audio-technica.com/cms/site/d0c406516fd8b42b/ for description and examples of the problem they used to cause
« Reply #24 on: October 17, 2013, 12:36:46 pm »
It's only marginally priced.
