It'll take me a day to design the board after we have the circuit work done.
Then you have never designed a board which is even vaguely complex or challenging.
A guy on the Altium forum has done a board with 24 layers, 14k5 components, 32k vias, 59k pads, 9k5 nets. The board and revisions took over a year, the hours spent on it were described as too many to count.
Easy there tiger. I was really just meaning to make a general comparison as to how the time gets distributed. I didn't literally mean a day, my fault. All I meant to convey is that as a general ratio, the PCB is the least of the concern with the work I do. I have spent several weeks on a single PCB version before. Most of the PCBs I deal with are 6-8 layers, but I have worked on as high as 14 before. But after the initial board design assuming testing goes well, I generally won't need to touch the PCB design again for a long time. I could go months. Maybe a tiny iteration here and there, but nothing major. 24 layers with tens of thousands of components? Like I said, PCB Monkeys
Definitely never worked on anything like that. I'm curious what would require a board with that many layers. I've had stuff with a pretty high component count, but it has always been distributed between multiple boards connected by ribbon or something else. Mostly large DAQ/control systems. I suppose we could have squeezed things on a single board, but this would have been cost prohibitive and just a lot of needless work.
At any rate, even with the complexity you're talking about though, what does Altium do with regards to the PCB design that makes it so much better? Specifically what features? I'm just kicking the tires over here, so maybe I don't even know what I've got in front of me, but the core PCB features feel about the same as Eagle.
