Author Topic: EEVblog #516 - LTSPICE Tutorial - DC Operating Point Analysis  (Read 39444 times)
Offline c4757p
  • adieu
Re: EEVblog #516 - LTSPICE Tutorial - DC Operating Point Analysis
« Reply #25 on: September 08, 2013, 05:20:15 pm »
Build the schematics yourself, it's good to get practice. If you just "play along" you'll only learn the parts you're interested in.
Offline mmagin
« Reply #26 on: September 08, 2013, 05:25:52 pm »
Has anyone tried the fairly new Mac OS X build of LTSpice found that it's as broken as I have?  Wondering if it's just me.
(Menu items missing, sometimes have to force quit it, schematic editing works, can't set up a simulation.)
I may just give it up on it and use it on my Windows machine, but then I have to make the install work with UAC (as a long-time user of real multi-user operating systems, I think turning off UAC globally is a dumb thing to do.)
Offline dr.diesel
« Reply #27 on: September 08, 2013, 05:30:04 pm »
And LTSpice is available for Windows, GNU/Linux and MacOS.
Mmmmmmm, they didn't used to, gonna have to check that out!
Offline c4757p
  • adieu
« Reply #28 on: September 08, 2013, 05:31:27 pm »
LTspice works very well under Linux with WINE, I imagine it would work similarly well if you installed the Windows version under WINE on Mac.
Really? I don't see it, I just see the Mac version. Or by "available" do you mean "under WINE" :-//
Offline jancumps
  • New Low
« Reply #29 on: September 08, 2013, 06:39:42 pm »
Yes, it needs Wine. I just installed it under Ubuntu to follow alongg with this video.
Initialy I had installed the linux version of Spice and tried to couple it with the Linux version of KiCad, but that didn't work out. The penguins didn't align.
Offline rizzy
« Reply #30 on: September 08, 2013, 07:12:44 pm »
Do they on Windoze?
Offline wblackledg
« Reply #31 on: September 08, 2013, 08:31:37 pm »
Anyway, you haven't put your home country in your profile, so I don't know whether advising you on how to simulate a crystal radio in SPICE would be considered aiding and abetting criminal blasphemy.
Well, I'm an American, if that's what you mean?  :-DD
Offline jancumps
  • New Low
« Reply #32 on: September 08, 2013, 10:48:30 pm »
Do they on Windoze?
Don't know. I never tried that.
Offline Totoro
    • The Belfry
« Reply #33 on: September 09, 2013, 11:12:33 am »
Thank you, Dave for the LTSPICE tutorial. Please continue! I look forward to them.
I have LTSPICE with Wine on Mac OS X and want to learn more!
Offline dentaku
« Reply #34 on: September 09, 2013, 11:44:34 am »
I've never been happy with the interface of LTSPICE.
I wish they would just let you pan around the screen while holding down the spacebar for one, more like Adobe Illustrator.
ALSO: How was Dave getting an arrow pointer instead of the crosshair most of the time?
It's difficult to select stuff in LTSPICE and it needs more shortcut keys.
An interface that has a scissor tool is clumsy too. Just let me right-click on something OR draw a square around things then press the Delete key.
It's nice software, it's just the interface that's annoying to try and figure out.
Maybe I just haven't tried hard enough.
Offline Rigby
  • Learning, very new at this. Righteous Asshole, too
« Reply #35 on: September 09, 2013, 11:50:25 am »
LTSpice is software that considers perfect UI to be a secondary (or tertiary) concern.  It seems that simulation functionality is the primary concern of the development team.
I wouldn't worry about these things too much.  Lots of application specific software has weird bugs and a general lack of polish.  Often this is due to a near complete focus on the core functionality of the application.  In my experience, the more specific the software, the less polish there is.  This is certainly true in software that I write.  I care much more for correct output than anything else, so that's what I spend my time on.
Offline gotnoise
  • Country: at
« Reply #36 on: September 09, 2013, 03:58:49 pm »
Thanks a million, Dave! This series is already (and will be) very helpful!
I do realize that many of your viewers are advanced and probably bored by the content. You mentioned this problem previously, and that you won't reach the same viewer count as compared to your other videos. But please keep producing LTSpice tutorials. I am sure you will be able to recruit more beginners to your vlog crowd, so on the long run you might get good viewer counts with this as well. And whoever does not like the content, nobody has to watch it. We can just pick whatever fits our bill anyway.
Offline Bored@Work
« Reply #37 on: September 09, 2013, 04:50:54 pm »
There is no development team. There is one guy. And he seems to be stuck in the '70th when it comes to user interfaces.
LTspice follows the old "select a tool and then manipulate the drawing with the tool" paradigm. This emerged in CAD as a 1:1 copy of the way draftsmen used to work. Select a pen of a particular size and draw as many lines as possible with that pen. Then change to another pen. Then to the compass (or is it compasses?), and do as many as possible with it before changing to yet another tool.
While modern user interfaces use an object-oriented approach. First select the object to manipulate, then the operation to apply to the object.
I would, if it would be my application. It is very typical for LTspice that users don't find functions. Often not even the much hated last resort - reading the manual - works for some things, because they aren't documented. LTspice's user interface is as bad as some open-source EDA software user interfaces.
« Last Edit: September 09, 2013, 04:52:42 pm by Bored@Work »
Offline hikariuk
« Reply #38 on: September 09, 2013, 05:02:42 pm »
I note its original name was "SwitcherCAD".
I write software.  I'd far rather be doing something else.
Offline firewalker
  • Country: gr
« Reply #39 on: September 09, 2013, 05:46:21 pm »
Persuade LT to open source LTSpice.
After that we can make it accept python addons! Bored@Work?  :-DD :-DD :-DD
I believe no one in LT wants to take over and polish it. Maybe after the retirement of the solo developer there will be a major redesign. Probably polished, only for Windows and not free of charge.  >:D >:D >:D
Alexander.
Offline ales22
  • Country: cz
« Reply #40 on: September 09, 2013, 06:00:15 pm »
Great little tool for beginners is Analog Circuit Simulator Applet here http://www.falstad.com/mathphysics.html. It's not for detailed analysis, but rather for demonstration of basic principles - it has many example circuits predefined and ready to try. It helped me many times in EE studies.
Offline firewalker
  • Country: gr
« Reply #41 on: September 09, 2013, 06:02:15 pm »
BTW. What language they use for LTspice?
Alexander.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #42 on: September 09, 2013, 06:08:50 pm »
Great video Dave  :-+ please do more of the same.
Offline Bored@Work
« Reply #43 on: September 09, 2013, 06:20:11 pm »
Won't happen. If they fear one thing than that someone reverse-engineers or otherwise learns about the inner working of LTspice when it comes to their proprietary, encrypted switcher models.
Microsoft Visual C++.
Offline firewalker
  • Country: gr
« Reply #44 on: September 09, 2013, 06:41:35 pm »
They could keep the engine closed and split it from the gui. Although I don;t know if it worth the hassle.
Alexander.
Offline ondreji
« Reply #45 on: September 09, 2013, 10:42:58 pm »
Indeed, it's quirky. I wasn't able to rotate placed component :). On the other hand I didn't try very hard. So far, it looks better to use Wine and win version of LT Spice. Anyway, I used it for lees than 5 minutes...
Offline mmagin
« Reply #46 on: September 10, 2013, 12:27:43 am »
Yep, I've gone and ran it under wine as well, and that way it seems to work flawlessly so far
Offline Bored@Work
« Reply #47 on: September 10, 2013, 05:50:54 am »
Yes, LTspice/SwitcherCAD. The binary is still called scad3.exe. Because ...
... it was once split. Into the schematic capture part (SwitcherCAD), and the SPICE engine (LTspice). But they put that into one binary. And after some releases, they just renamed the combination LTspice IV.
Makes you wounder if they still have their SPICE engine run separately in other inhouse tools. Because that is how LTspice/SwitcherCAD started, as an inhouse tool which they later opened up to customers.
What I always find sad with all the manufacturer-specific SPICE versions is that all the manufacturers never cooperated to just settle on a single industry-wide standardized SPICE version. Manufacturers do cooperate in standard committees for some things, but they could never be bothered or didn't manage to do that to evolve SPICE.
Offline Rigby
« Reply #48 on: September 10, 2013, 09:41:07 am »
There's always going to be a certain amount of pride that will impede this notion.  I agree with you that this would be nice indeed, but Manufacturer A doesn't want to put a lot of effort into a tool that lets users see that Manufacturer B's part is exactly what they need.
Offline dentaku
« Reply #49 on: September 10, 2013, 12:54:14 pm »
So... I guess my question would be
How did Dave get that arrow pointer during his demo?
I always end up with the crosshair tool, scissors, hand etc.. but I've never seen a regular old white arrow tool like you'd expect in any drawing tool (like Illustrator) that you can use for selecting things.
Was that arrow pointer maybe something his screen capture software provides (it WAS extra big looking).
Multisim might not have a nice interface either but from what I can see at least it seems to follow some of the regular UI conventions. Of course it's not a free application.
