Author Topic: EEVblog 1514 - Heat Pump Hot Water Install & Analysis  (Read 1952 times)
Offline EEVblogTopic starter
« on: November 11, 2022, 11:13:47 pm »
Replacing my gas tank hot water system with an electric heat pump system to use my excess solar power energy.
Before and after measurements and anlysis of the results.
00:00 - Measurements on existing Rheem 175L gas tank hot water system
04:00 - Installation of new Reclaim 415L Heat Pump hot water system
06:39 - Pipe work and tempering valve
09:27 - Temperature Measurements
10:00 - Standby power consumption
10:21 - Anlysis of measurements on whiteboard
15:00 - So the thermal calculations match the measurements?
17:13 - Never believe manufacturer claims!
18:00 - How more efficient is a Heat Pump system vs Gas?
Offline ssander
Re: EEVblog 1514 - Heat Pump Hot Water Install & Analysis
« Reply #1 on: November 12, 2022, 12:09:18 pm »
Hi, The video is missing.  :(
Says it is from your private collection  :o
The following users thanked this post: Jacon
« Reply #2 on: November 12, 2022, 11:33:16 pm »
Yes, taken down. I'm collecting more data and am waiting for some info from Reclaim.
Discussion is here:
https://www.eevblog.com/forum/blog/heat-pump-hot-water-system-vs-gas-hot-water/
« Last Edit: November 13, 2022, 06:39:47 am by EEVblog »
Offline Bzzz
  • shoving atoms
    • Wan Hung Lo Electronics Blog :)
« Reply #3 on: November 12, 2022, 11:48:28 pm »
Discussion link doesn't work unfortunately.
Regardless, and I have not seen the eevblog2 video or verified the calculations: If one needs 3kWh to heat up the water (plus the tank) from T1 to T2, and the heat pump uses exactly that - what is the point of the heat pump? A resistive heater will do the exact same thing minus all the expensive moving bits that can go wrong. Are we sure the heat pump is actually working?
« Reply #4 on: November 13, 2022, 06:40:49 am »
Link fixed.
Yes it's working, the 3kWh heat figure was wrong.
