Author Topic: EEVblog #507 - The First ARM Computer - Acorn Archimedes A3000  (Read 31498 times)
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: EEVblog #507 - The First ARM Computer - Acorn Archimedes A3000
« Reply #50 on: July 19, 2014, 12:21:00 pm »
I don't think the problem is with corroded roms only. It should output some video signal even without ram, rom and cpu. So, first step would be to make it to generate video, and only then to fix the roms
No - it needs the video & memory controllers to be set up by the firmware to produce a video signal
Day Job: Mostly LEDs
Offline EEVblogTopic starter
« Reply #51 on: July 19, 2014, 01:57:13 pm »
I was just watching the video and was curious to now what became of Dave's BBC Micro. Did he restore it? Did he junk it?
Still got it, but it's beyond economical repair.
My recommendation is to strip out the internal board and replace it with a 512 mb Raspberry Pi>
Could be done if I could find the time...
Offline muffenme
« Reply #52 on: November 16, 2014, 09:18:24 pm »
Bill a daughter board to replace the area that has been effected by the battery.   This looks to be a simple job from what I seen you do.  I like to see some image of the effected area.  Even today motherboard manufacturer has this ideal of putting a battery on the motherboard with protecting the board.
Offline Fungus
« Reply #53 on: November 17, 2014, 10:25:53 am »
I actually had one of those things back in the 80's...
