@9:20
No dave, this is not a "very good display let me tell ya". This was a good display in 2004 when Sony PSP came out.
This is the CHEAPEST TN screen they could find. In Tablets this is considered garbage bin quality. Difference between weak 480x272 TN screen and 1024x600 IPS is about $15. Agilent decided they like $15 better than perfect viewing angles. How much do you value proper (no discoloration/negative colors) viewing angles?
This smells like a bean counter decision, or no boots on the ground in Asian parts supplier market.
Yes, one can argue this is the best display available in bench meters, but its like saying sand flavored ice cream is the best ice cream in Sahara Desert because its way better than camel shit ice cream.
Win CE booting 50 seconds - you can see it is going through detecting hardware phase - this is most retarded on fixed hardware design. Its not like its going to boot up one day on a different motherboard with less ram and bigger screen. Shows how lazy person doing Windows integration was. Firmware like this should boot same way suspend to disc works, with preselected batch of drivers and plug&play disabled.
Other than that great meter.
btw: Chris was right once again - IPad app for bench instruments
Oscilloscopes are next
