These printers are always a good source of parts. Unfortunately, the newer ones are very cheaply built, older ones are best for really solid components. I still have an old HP laserjet IID waiting to be taken apart, that thing is massive!
In terms of parts/subassemblies to salvage, the fuser unit can be repurposed into a laminator quite easily. I have one that I used for toner transfer PCBs. You didn't mention the crystals on the boards Dave, I feel these are always worth grabbing.
My approach to the salvaging of PCB mounted components has changed somewhat over the years. I used to methodically desolder all of the components with a heat gun, and sort them out into my parts drawers. However, I got such a backlog of PCBs to process, that I just decided to keep the intact boards, and rummage through them all whenever I need a particular component in a hurry. I keep two categories of PCBs: ones that contain functioning subsystems, and ones that are only for parts.
Regarding the spring clip with the resistor and diode, it looks like part of the HV electrostatic circuitry, with the clips making contact with the toner cartridge. I think that resistor may have been a HV type.
It is interesting to note that everything is moving towards DC motors for positioning. All the old printers used to use stepper motors for this. I suppose the electronics required to output a bitstream synchronised to the motor feedback signal is now cheaper than using a stepper.
