Author Topic: EEVblog #478 - Keithley 2015 THD Multimeter Teardown  (Read 34591 times)
Offline EEVblogTopic starter
« on: June 04, 2013, 11:29:11 pm »
Teardown Tuesday
Inside the Keithley 2015 THD 6.5 digit bench multimeter.
Not just a multimeter, it does low noise signal generation and automated audio THD system measurement.
Offline ChadSeibert
Re: EEVblog #478 - Keithley 2015 THD Multimeter Teardown
« Reply #1 on: June 05, 2013, 01:44:46 am »
Excellent teardown as always, Dave! Do you know whether there is a niche application where a meter with all this functionality would be useful?
« Reply #2 on: June 05, 2013, 02:19:52 am »
Production testing of any device that has audio/voice capability.
It's not designed for high end hi-fi type testing, but phones, radios, or any other such voice channel quality sound is required it would be ideal.
The datasheet for example lists applications like
• Wireless communication device audio quality testing
• Component linearity testing
• Lighting and ballast THD limit conformance testing
• Telephone and automotive speaker testing
« Last Edit: June 05, 2013, 02:22:44 am by EEVblog »
Offline chickenHeadKnob
« Reply #3 on: June 05, 2013, 03:03:27 am »
Great, just great, another quality multimeter/o'sillyscope that is going to get the Dave endorsement price inflation.
Yes I did get moist while you were performing the tear-down.
The one question I had was does this meter have one of those accursed battery backed RAM for CAL. data. You go fast sometimes and I thought maybe I missed it. So I checked on the internets. Assuming model 2000 and 2015 share the same main board, the answer is no.
The 2000 model repair manual lists U136 and calls it NVram in the block diagram and eprom in the parts list, but it is just a jelly bean 24lc16b 16K bit EEprom.
Offline carloscuev
  • Country: mx
    • Spanish Freescale Developers Forum
« Reply #4 on: June 05, 2013, 03:10:55 am »
Just as the FE-5680A Rubidium Atomic Frequency Standard Oscillator on eBay, you could get them for $50 before dave's first videos about them, now ou're lucky if you find them at $80
Offline nukie
« Reply #5 on: June 05, 2013, 03:11:27 am »
I know you mention cap, but most LM399 and LTZ1000 references have wobbly cap, the pins however are securely mounted on the sockets.
Good choice with the Keithley I prefer the Keithley 2000 over HP34401A. The Keithley 2015 is ALOT MORE MEAT than the 2000 model.
« Last Edit: June 05, 2013, 03:47:58 am by nukie »
Offline ChadSeibert
« Reply #6 on: June 05, 2013, 03:27:10 am »
Eh, I got my $45 shipped three weeks after his review/teardown :). Maybe this is just a bad time?
« Reply #7 on: June 05, 2013, 04:03:05 am »
Hmm, I thought there was software to go with this meter that could do general purpose THD testing bode plots etc, but I can't seem to find anything, just some drivers.
Anyone?
Offline FrankBuss
    • Frank Buss
« Reply #8 on: June 05, 2013, 04:17:13 am »
Interesting teardown. Looking forward to your test of the THD measurement. Once I've used an Audio Precision device for audio development (not my own, at a client site, too expensive for me) and measuring distortions of -100 dB and less was no problem at all.
« Reply #9 on: June 05, 2013, 05:17:24 am »
I used to have an Audio Precision in my lab until SWMBO found out it was worth 5 figures and I had to sell it  :(
Offline synapsis
    • Blackcow
« Reply #10 on: June 05, 2013, 06:01:44 am »
Long time viewer, first time poster. Thanks for all the education you're giving for free, this programmer appreciates it.
Here's a photo of the top board of my Keithley 2000 for comparison. Where the siggen board is on the 2015, mine has an option slot which I believe is for a multichannel scanning/switching array of thermocouples.
Offline cyr
« Reply #11 on: June 05, 2013, 06:19:14 am »
There seems to be a lot of these around now on ebay, most probably from some automated test rigs. Mine originally comes from Rohde & Schwarz according to the cal sticker (two T&M companies for the price of one).
I don't think I will ever use the THD function, but it's a very nice general purpose bench meter...
« Reply #12 on: June 05, 2013, 06:29:36 am »
Thanks.
As I suspected, you can't have the scanner on the 2015. The 2015 is essentially a 2000 with the THD option instead of the scanner option.
Offline ChadSeibert
« Reply #13 on: June 05, 2013, 06:30:12 am »
You've got to be shitting me . :wtf: Was it a down payment for this? http://design.kay-diamonds.com/diamonds/diamond/diam125977/
« Last Edit: June 05, 2013, 06:45:00 am by ChadSeibert »
Offline KJDS
    • my website holding page
« Reply #14 on: June 05, 2013, 07:56:12 am »
Thanks for the teardown, I've not looked inside one before.
Offline bingo600
« Reply #15 on: June 05, 2013, 08:08:20 am »
But only if you use THD , Keithley says it's a 2000 engine with THD added
http://forum.keithley.com/phpBB3/viewtopic.php?p=92667&sid=42116ccd061059f45ab4acb066b32cc2#p92667
/Bingo
Offline FrankBuss
    • Frank Buss
« Reply #16 on: June 05, 2013, 08:13:05 am »
And I guess what hurts most is that probably she was right, because I guess you don't measure professional audio equipment with balanced analog IOs or AES3 regularly, or need to create characteristics curves of audio amplifiers :P
Offline ChadSeibert
« Reply #17 on: June 05, 2013, 11:21:32 am »
True, but Dave doesn't strike me as the kind of person that would be put off owning a piece of equipment just because he doesn't have a use for it. And imagine the teardown of that machine.  :(
Offline ChadSeibert
« Reply #18 on: June 05, 2013, 11:32:29 am »
It's $850 refurbished at valuetronics, but I'm sure it's not cal'ed. Does anyone know if they are a reputable vendor?
https://www.valuetronics.com/detail/Used-keithley-2015-p.cfm?gclid=CJaixePnzLcCFa5DMgod3j4Axg#.Ua8gtJwizSk
Thanks,
Chad
Offline plesa
« Reply #19 on: June 05, 2013, 12:05:17 pm »
Anyone?
Hi Dave,
I just found Labview program http://www.keithley.com/products/dcac/audioanalyzer/?path=2015/Downloads#1
In attachment you can find prebuilded application. Just install Labview runtime engine.
The following users thanked this post: materialsguy
« Reply #20 on: June 05, 2013, 12:12:00 pm »
Nope. Bought it (2700 series http://www.ap.com/products/2700) from my previous company that was shutting down for $500! Hardly used, and just freshly cal'd.
Interesting story actually:
They knew how much it was worth (we paid like $30K for it or something) and wanted to keep it for their overseas operation (they were just shutting down the oz office). But when I turned up on the day for some other stuff I was buying I was told to bring some cash just in case there was some leftover stuff I wanted. The guy in charge of clearing out the gear said the company had been dicking around about the unit, and technically he was ordered to clear everything, so asked if I wanted to make an offer (he didn't care, he was getting the arse anyway!), but I had to pay and take it right there and then as tomorrow it would likely be shipped out. Hell yeah, I had an extra $500 in my pocket and asked if that would do.
Had to go around and get a few signatures, which raised many eyebrows,  but I walked out with it with a big grin :-+
There was likely someone at HQ who was really pissed!
Eventually sold it on ebay for $13K or so, my biggest score ever!  :-+
Hard to justify keeping something like that.
This was before the blog. I had a lot of cool gear like that I scored before the blog, and sold most of it, so they never made it on video.
« Last Edit: June 05, 2013, 12:26:35 pm by EEVblog »
Offline bingo600
« Reply #21 on: June 05, 2013, 12:26:25 pm »
Thanks,
Chad
It's cheaper (I think) @KJDS (forumuser)
http://www.ebay.co.uk/itm/Keithley-2015THD-6-5-digit-bench-DMM-multimeter-with-harmonic-analysis-/350803796454
The one i bought from him in april was Cal'ed on May-2011 , meaning it's almost valid ....
Maybe give him a PM , there "might be" some forum discount.
https://www.eevblog.com/forum/blog/eevblog-478-keithley-2015-thd-multimeter-teardown/msg242087/#msg242087
/Bingo
« Last Edit: June 05, 2013, 12:28:33 pm by bingo600 »
Offline ChadSeibert
« Reply #22 on: June 05, 2013, 01:08:15 pm »
Thanks,
Chad
/Bingo
I'll give it some thought, but shipping to the US is pretty expensive. Still cheaper, though.
Quote from: EEVblog
Interesting story, but it's probably best that you don't share everything you've sold. Some of us might not be able to take it :).
« Last Edit: June 05, 2013, 01:15:21 pm by ChadSeibert »
Offline KJDS
« Reply #23 on: June 05, 2013, 01:13:05 pm »
I'm happy to give forum members a discount on any of my products.
Shipping to the US isn't horrible, and I can remove the VAT which compensates substantially to the shipping cost. It's possible that you'll get stung with import taxes but I have no control of that.
« Last Edit: June 05, 2013, 01:15:52 pm by KJDS »
Offline free_electron
    • SiliconValleyGarage
« Reply #24 on: June 05, 2013, 03:48:32 pm »
The opto isolation on the siggen is not so much as to split analog and digital but the fact that the digital is chassis referenced and the analog is floating ( notice the usage of fully isolated bnc connectors that have no metallic connection to chassis)
