Well, despite some nay-saying above, I purchased the GW-Instek 2304A and a B&K 5054 25 MHz Function generator to go with it. I only just got the boxes via UPS an hour ago, but all is up and running properly. I am quite happy with the Instek. The style may be dated but it all works fine. A 25Mhz Sine Wave shows up properly. The Square Wave is not very square past 5Mz but they are constant voltage throughout the range which is fine. <--- Fixed! The default setup is for high output impedance and I had terminated the cable with a 50 ohm load. I set the B&K to use low output impedance (50 ohm) and now the square wave at 25 MHz is just fine - nice and square and good fast rise time.
The probes are good and BNC connectors are well done. Somebody panned the probes but mine are fine. I have Tektronix 10X probes to compare with and the Instek probes are fine.
So my first impression is that I got a decent machine. Valuetronics sold it to me less than list and threw in the function generator for free. My B&K is better (and note my fix above).
So I retired 2 7000 series scopes, an old HP Function Generator (bad power supply) and my Fluke 8022 digital meter. I got a Fluke 87V and that is a swell meter.
.... C
