Author Topic: EEVblog #470 - Agilent N9344C 20GHz Spectrum Analyser Teardown  (Read 29065 times)
Offline nitro2k01Topic starter
Offline Laidukas
Re: EEVblog #470 - Agilent N9344C 20GHz Spectrum Analyser Teardown
« Reply #1 on: May 15, 2013, 06:37:20 am »
Dave, were you wearing a wrist strap for ESD protection during this tear down? I think Agilent guys hope you did  :)
Offline babi
« Reply #2 on: May 15, 2013, 07:22:10 am »
Hi Dave
Did you get any high-res photos of the RF micro-strips on the PCB?
Offline EEVblog
« Reply #3 on: May 15, 2013, 07:51:31 am »
Some photos on my Flickr site, but just 2MP taken with the video camera.
Offline JoeMuc2013
« Reply #4 on: May 15, 2013, 09:21:48 am »
Hello Dave,
what a beauty once again. Just one thing I didn't like is the odd placement of the L2 inductor on the input board at 39:53 in the video (left side) and also shown in some of the closeups at Flickr. I guess there is no "RF" reason for doing this? Just a small flaw I'm not used to see from Agilent. Well, it appears to be working though, right?
Did you manage to put it back together? :)
Greetz
Joe
Offline icon
« Reply #5 on: May 15, 2013, 12:02:24 pm »
"Looks like a phillips, smells like a phillips" - but isn't. Is therefore, possibly, a Japanese Industrial Standard screw? Found in laptops and other consumer electronics, on the adjustments of Shimano derailleur mechs, on RC helis, on the lids of Nissin motorcycle brake fluid reservoirs, etc. I have a set of Hozan JIS screwdrivers that get a lot more use than you'd think. A phillips screwdriver will rapidly knacker a JIS head, especially as they seem often to be made of some kind of silvery cheese.
John
« Reply #6 on: May 15, 2013, 12:08:51 pm »
JIS is easy to identify, the head has a small depression on the one side to indicate that it is JIS.
Offline KJDS
    • my website holding page
« Reply #7 on: May 15, 2013, 12:27:58 pm »
Circuit design by Slartibartfast. Just as RF should be.
Offline saturation
  • Doveryai, no proveryai
    • NIST
« Reply #8 on: May 15, 2013, 12:39:12 pm »
GHz RF, always a blast to see layouts, so black magic.  :-+
Best Wishes,
 Saturation
Offline free_electron
    • SiliconValleyGarage
« Reply #9 on: May 15, 2013, 01:31:50 pm »
Could very well be. He always loved the fiddly bits like the fjords of norway...
The reason for having gps onboard this machine is that it most likely is a site analyser. These are used to measure field strength for things like wifi and cell phones. Hook it up to a pc with mapping software and drive around. And it builds you the power map.
Offline EEVblog
« Reply #10 on: May 15, 2013, 01:38:07 pm »
Yes, its inclusion was driven from customer requirements for that.
Offline icon
« Reply #11 on: May 15, 2013, 01:55:13 pm »
JIS is easy to identify, if the head has a small depression on the one side to indicate that it is JIS.
Edited.
I've often encountered 'phillips' (ie not Pozidriv type) screws with no markings, but which no size of phillips screwdriver will properly fit. JIS usually do the job (if I haven't rounded the damn thing in the process of discovery - then it's Dremel-time).
John
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #12 on: May 15, 2013, 02:23:23 pm »
Can it use it for a frequency reference I wonder?
This reminds me of a story I heard a while ago - in the early days of analogue cellphones, Vodafone had some vans which used to drive around to evaluate call-site performance - because of the test gear they were using, they had to drive round fairly slowly, and on a couple of occsions got pulled over by cops thinking they were kerb-crawling - apparently they were persuaded otherwise by all the gear in the back!
Day Job: Mostly LEDs
Offline lewis
  • Nullius in verba
« Reply #13 on: May 15, 2013, 02:49:37 pm »
Voodoo black magic shit.
I will not be pushed, filed, stamped, indexed, briefed, debriefed or numbered.
« Reply #14 on: May 15, 2013, 03:01:28 pm »
Dremel not always going to work, but you can get left hand cutting drill bits, or my favourite item, a Ridgid extractor kit. The left hand drill bits both drill and loosen the screw, great in a deep recess. Just need a reversible drill, and tighten the chuck pretty tight.
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #15 on: May 15, 2013, 03:29:17 pm »
There are some places riddled with what I would call sloppy soldering, and those botches, what a crap job..
And there is lots of flux residues, I was watching and screaming, like how can you call that top notch quality? |O
Online BravoV
  • +++ ATH1
« Reply #16 on: May 15, 2013, 03:38:20 pm »
Probably that is a working unit but with the calibration way out of whack big times beyond repair, and also might be as a target practice for noob repair/cal staffs to play with ? :-//
Offline senso
  • Country: pt
    • My AVR tutorials
« Reply #17 on: May 15, 2013, 04:04:39 pm »
Some examples, there is more top notch quality showing all over those boards, it seems really smart having expensive controlled dieletric pcb's and then just apply some dabs of random flux all over the impedance controlled traces, must be the secret sauce  ::)
« Reply #18 on: May 15, 2013, 04:12:03 pm »
Those little white chips are Mini circuits amplifiers, some are capable of a flat response from close to DC to close to light. Give away is the power feed, a feedthrough ceramic cap, a chip inductor, a decoupling cap to ground then a feed resistor to the output of the chip. The numbers are an indication of the maximum signal level they can linearly handle. On the input PCB the funny thing with 2 lines next to each other and a resistor on the far end is a sampling loop, probably going to a simple rectifier and a signal strength indicator, though it probably has a connection to the gain stages so as to give a constant level to the ADC stages as it is scanned through the passband.
Offline Corporate666
  • Remember, you are unique, just like everybody else
« Reply #19 on: May 15, 2013, 07:50:16 pm »
Always interesting to see PCB design at a level light years beyond what I do (or ever will do).
Obviously these guys get special training to be able to do that - they aren't just first year EE grads doing those layouts.  Is high-end RF design something that is taught at the masters level, or (as I would guess) based more on in-house knowledge that is passed from generation to generation within a company like Agilent?
Anyone else notice the Chinglish on the stickers?  Left Borad and Right Borad?  :-DD
It's not always the most popular person who gets the job done.
Offline Watermelon
« Reply #20 on: May 15, 2013, 08:13:14 pm »
Does anyone has a datasheet available for those odd 4 leaded RF amplifiers? Cannot find any at first glance  :-//
Offline Hydrawerk
« Reply #21 on: May 15, 2013, 08:15:56 pm »
Did you reassemble this insturment? Does it work again?
« Last Edit: May 15, 2013, 11:23:18 pm by Hydrawerk »
Offline KJDS
« Reply #22 on: May 15, 2013, 08:29:38 pm »
Decent RF design is mostly learnt on the job. My bachelors and masters degrees both had RF projects which provided some basic understanding, but I didn't really know what I was doing until I'd spent ten years or so learning on the job.
I remember one of my undergraduate courses had 20 hours of lectures on the Smith chart and I barely understood how to do something basic with it, whereas now it's second nature. That only comes with spending a lot of time on it and that's just a tiny part of RF. A lot of RF engineers are specialists, so will only play seriously with say LNAs or high power or filters or mixers rather than being bale to readily pick up things from a broad spectrum of the building blocks used in RF. There are certainly very few that are genuinely good at say, both high power RF amplifier design and cavity filter design, certainly if they had to do something from first principal rather than relying on synthesis software.
Offline krenzo
« Reply #23 on: May 15, 2013, 08:34:44 pm »
Look for "4-Micro-X" as the Package / Case.  There are a few on DigiKey that do 0-12 GHz amplification from RFMD: http://www.digikey.com/product-detail/en/NBB-310-T1/689-1001-1-ND/1302337
This one has "N4" on the package like in the picture above.
« Last Edit: May 15, 2013, 08:39:51 pm by krenzo »
Offline robin_
« Reply #24 on: May 15, 2013, 10:28:08 pm »
I’m wondering what these bodge wires are for. What kind of mistakes in the board layout remain unnoticed up until the board is already in production? And in which kind of situations is it even possible to still being able fix it with hacking in small wires afterwards?
