Here's an unusual C-W app! We needed to build 2 cosmic ray telescopes to operate on 2 space craft (the first to leave our Solar System). There were 3 photomultipliers which needed a bit over 1000 VDC each. Vacuum chamber testing revealed super bad corona discharge problems generating high system noise. Since each PMT had 10 dynodes, each needing a 100 VDC difference from its neighbors, we made a 100 VAC 100 KHz power supply feeding a 10 stage C-W generator on each tube. When C-Ws were carefully potted onto each PMT, all corona problems went away!
NASA said we'd probably have data till 100,000,000 miles out, and we did. So they sent back our Ground Support Equipment which pulled our data out of the stream. Over 14 years later, we got an emergency call to return our GSE because we had made it around the Sun and baby was catching up with Earth again. Our Cosmic Ray Anisotropy package was still working perfectly and we got an entire additional data set that was unanticipated.
So, Huzzah! Huzzah! for the Cockcroft-Walton Multipliers!
