They used a special power adapter and plug for isolation? God I hate having to keep track of those! Why couldn't they just use a little inverter to provide their own isolation to whatever adapter you use? There can't be much cost difference between the external transformer and an internal one - throw in a couple $0.03 transistors and you have yourself an inverter!
Old video and old comments, but I'm optimistic.
Could you explain what you mean by isolation? Isolation from Mains Ground?
Also Dave at 8:11 says "Linear adapter higher isolation voltage" when referring to the input. Could someone explain or point me in a direction? Thanks
