Author Topic: EEVblog #446 - Dumpster Diving Samsung Plasma TV  (Read 36497 times)
Online tom66
Re: EEVblog #446 - Dumpster Diving Samsung Plasma TV
« Reply #25 on: March 30, 2013, 04:10:09 pm »
I'm watching one I repaired right now. The technology has come quite far, but it still doesn't look quite right to me -- I'm not sure why, I can't put my finger on it.
Offline free_electron
    • SiliconValleyGarage
« Reply #26 on: March 30, 2013, 04:28:33 pm »
the dead giveaway on those 'caps' is the writing : 10uH   >:D
they are the integration inductors for the class-t audio amplifier
Online tom66
« Reply #27 on: March 30, 2013, 04:30:49 pm »
Probably just class D. They're to limit the EMI produced by the switching output.
Offline ZeroStatic
« Reply #28 on: March 30, 2013, 06:08:56 pm »
If the analog inputs are not working, I'd suspect a voltage rail is down in the input processing section. Check the rails around the philips SAA7119 chip.
Online AndyC_772
« Reply #29 on: March 30, 2013, 07:52:52 pm »
I feel much the same way about LCD, even the best screens have a slightly smeary, almost greasy look to them which I just don't enjoy watching. For me a plasma screen was the obvious choice when I finally decided to upgrade my 10+ year old CRT.
Online tom66
« Reply #30 on: March 30, 2013, 11:20:34 pm »
Some other corrections (sorry Dave!)
Those Y-drivers are actually TQFP ICs (not BGA), each is usually 64~96 bit, with older sets having lower densities. By the way, that is minimum 64 channels capable of switching 200V so the IC design is not trivial...
http://www.fujielectric.com/company/tech/pdf/r51-2/07.pdf
The glue is necessary because humid air can otherwise lead to early failure.
The X-drivers are by necessity bonded onto the panel. With 1024 lines x RGB you need = 3072 columns, over approx 100cm you need ~31 columns per cm minimum (0.32mm pitch.) That's beyond the density of typical connectors -- not impossible but expensive. Each TCP IC switches 256~384 channels at around 70V, newer ones are 55V using different panel tech, some really early panels used 85V.
Vs is determined by the gas pressure of the plasma panel. My dad's old NEC has a 165V Vsus, but most newer TVs are around 200V as panel technology improves.
« Last Edit: March 30, 2013, 11:25:23 pm by tom66 »
Offline Agony
  • Country: ee
« Reply #31 on: March 31, 2013, 01:13:00 am »
the SAA7.... chip thats on the yt video "pic" just looks soo wrong... it just looks as if it got a little too much heat.
Cant read out the complete info.. but partial search  shows its a digital video decoder.
« Last Edit: March 31, 2013, 01:18:47 am by Agony »
Bitcoin GHAS renting and 0% fee stratum mining.
https://cex.io/r/0/condemned/0/
Offline NiHaoMike
    • Facebook Page
« Reply #32 on: March 31, 2013, 01:31:04 am »
Have you tried the HDMI input?
Offline tec5c
« Reply #33 on: March 31, 2013, 07:25:42 am »
P.S Plasmas are banned in some countries due to excessive power consumption.
More like severely restricted... they still exist but the brightness is turned way down to keep power usage low. First thing I would do is go into the service mode and set it to make it think it's in the US or another country... boom goes up the brightness.
No. They are definitely banned in certain areas. The state of California has had a ban on the sale of plasma TV's since 2009. Put in place by the California Energy Commission center. Since this was put into effect, manufacturers have revised their technology to ensure that their products meet the energy consumption laws.
Plasma is a dying technology, it won't be all that long before they won't exist on the market in any country. Panasonic had the choice some years ago about which technology they would invest in. They chose plasma and built manufacturing warehouses. Now in retrospect, this was the wrong choice and they are fully aware of this. Panasonic now have a plan in place to get out of the plasma industry and within a number of years they will cease to manufacture any more plasma units.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #34 on: March 31, 2013, 08:54:13 am »
Well the Samsung TV seems to have lasted longer than my Samsung Cell phone, 10 months and it's knackered 2 months warranty left, wonder if they'll fix or replace, on the video that was the first time I've ever seen inside a plasma, I was given a broken LCD TV the screen was seeping, I thought there be lots of good stuff in there Wrong two boards power supply, and a main circuit board all surface mount, using the power supply, rest in the recycle bin.
no one would or will tell me how to delete this account
Online tom66
« Reply #35 on: March 31, 2013, 10:49:17 am »
I can only find proposals for California banning plasma tech. I don't think they've actually done so yet. They have mandated energy star requirements (IIRC so has every other state) which makes them much less attractive.
I think I'll keep my 4 year old Panny... I'm not bothered about the power bill yet...
Panasonic still makes plasma, about 5~5.5 million per year. Samsung make approx 4.5 million. LG make about 2.5~3 million. (LCD TV shipments are around 200 million, so it's a small piece of the pie.) Neither are in a rush to drop the niche technology yet... but they'll probably be gone by 2014~2015 though as OLED steps up to the plate. Panasonic are heavily investing in OLED with Sony, so that's where they will probably go.
Trouble I see for the TV industry is "where next"? OLED is almost perfection: Infinite contrast ratio, sub-millisecond response time, extremely good energy efficiency, very high colour depth.
You can't really improve it so will we have another stagnation like CRT tech for ~70 years until someone invents something like holographic true 3D displays? Meh, I hate 3D TV anyway.
Another thing I don't like about OLED is it is boring. Everything happens on the display panel. No high power electronics! I want big heatsinks, cooling fans, and a beefy power supply, like in a plasma.
« Last Edit: March 31, 2013, 10:51:06 am by tom66 »
Offline Rodville
  • Sense isn't common, just look around!
« Reply #36 on: March 31, 2013, 06:12:18 pm »
After watching the follow up I am more convinced then ever that there is either a loose cable or broken solder joint.
Offline Fezder
  • Lean on, or was it learn on?
« Reply #37 on: March 31, 2013, 06:15:25 pm »
followup? oo, gotta watch that. even if i would'nt understand half of it....
Both analog/digital hobbyist, reparing stuff from time to time
Offline Erwin
« Reply #38 on: March 31, 2013, 09:58:36 pm »
What about this? That does look broken.  ???
Offline NiHaoMike
    • Facebook Page
« Reply #39 on: March 31, 2013, 10:40:59 pm »
Throw in a Core i7 and some nice GPUs and you'll get all of those.
Online tom66
« Reply #40 on: March 31, 2013, 10:43:41 pm »
Hah... the newer TVs are coming out with quad-core 1.3GHz processors now.
Give me a "dumb" TV any day over a silly smart TV.
Offline Monkeh
« Reply #41 on: March 31, 2013, 11:05:28 pm »
... there's nothing wrong there.
Offline Erwin
« Reply #42 on: March 31, 2013, 11:24:20 pm »
I agree it could be a shadow of a solder blob on top, but from what I can see in the video, it does look like a crack in the solder joint. (that black streak has some very high contrast difference)
Edit: That thermal stress on the '10-bit video decoder' could well be from someone with a hot air gun, trying to repair it.
« Last Edit: March 31, 2013, 11:33:50 pm by Erwin »
Offline k8tek
« Reply #43 on: April 01, 2013, 12:47:46 am »
Nothing beats the old console CRTs.
Offline NiHaoMike
    • Facebook Page
« Reply #44 on: April 01, 2013, 01:55:22 am »
It would actually be quite interesting if they designed a TV that could run Windows or whatever x86 OS you wanted (like Linux). Or an ARM based TV that runs Android. A smart TV is actually great if done properly, but I'm not aware of any that are.
On the other end, I think there's quite a market for dumb TVs that are really just big monitors.
Offline leno
Offline adcurtin
« Reply #46 on: April 01, 2013, 07:08:47 am »
Hey Dave,
No one else has mentioned it, but it looks like you're using the Hauppage HD-PVR as your component generator. The HD-PVR does not generate a reliable component output when there is no valid input. My monitor (Dell u2410) despises the output and sleep mode goes in and out of sleep mode when there’s no input to the PVR. It's like the PVR is outputting a valid component signal for half a second every 5 seconds or so. Maybe it's the processor waking up the ADC to see if it's got an input yet.  Anyway, I wouldn't rely on that signal without a valid input to the PVR. I’d suggest trying a different component source.
Cheers.
Online tom66
« Reply #47 on: April 01, 2013, 08:11:20 am »
I want the TV to be a large, 1920x1080 display panel, nothing more. If smart features are included this adds a path for the TV to go out of date. I think this is the only way manufacturers will be able to "improve" each generation, with more/better smart features.
Offline hammil
« Reply #48 on: April 01, 2013, 12:15:22 pm »
Then buy a basic display panel, there are plenty of them... Like those used for computer displays.
'Smart' TVs started out by integrating the digital tuner into the body of the TV, which gives a much more seamless experience for the consumer, hence their popularity. As technology developed, companies started integrating more features, such as streaming, and even web browsing. If some feature doesn't fit the bill, the consumer is still free to plug in an external box, but in most cases the built-in variants are reliable enough to use.
Even if you bought a simple display panel, it will still eventually become obsolete. Huge flat-tube CRTs cost thousands, at one point, but now are almost useless. The first TFT displays were truly awful. And when we're all using millimetre-thick OLEDs (or similar) with million-to-one contrast ratios, we'll laugh at how silly we were with our plasmas and LCDs.
Offline kfitch42
« Reply #49 on: April 01, 2013, 12:17:21 pm »
I think that exists, it is called an iMac. :)
