Plasma is an energy sucking beast. I got a 46" 1080p Panasonic for £70 on eBay as faulty, it was just a loose cable. It pulls around 350~400W on average TV (around 100~150W on darker scenes) and exceeds the rated 470W on certain scenes -- for example a high contrast noise pattern uses about 630W!! A 1080p display uses a lot more than a 720p display, due to the larger surface area to volume ratio of the pixels (more pixel wall to absorb light, less efficient cell.)
However, overall, the reliability seems to be around that of an LCD TV. And the panels themselves are more reliable than LCD panels though vertical line failures are more common (which aren't repairable.)
Dave, here is something to try. You will need to source a Samsung remote which operates the TV -- however, one for a VCR, DVD player or another LCD will work too.
Turn TV into standby.
Press Info, Menu, Mute, Power.
Access service menu and perform a service reset.
(If that does not work try Mute, 1, 8, 2, Power for some sets.)
This fixes a lot of problems with Samsung TVs.
I encounter more Samsung than any other brand in my repair adventures -- "Friends don't let friends buy Samsung."
