Author Topic: EEVblog #520 - Michael's 3D Printer  (Read 20727 times)
Offline Michael Sullivan
Re: EEVblog #520 - Michael's 3D Printer
« Reply #25 on: October 07, 2013, 02:14:54 pm »
I agree with SeanB that the joiners need to be screwed as well to prevent vibration from shaking the joins apart.
Offline Janaha
« Reply #26 on: October 07, 2013, 08:16:07 pm »
I realys like to see it printing, a specialy using it's two printheads together. I realy like the idea with those two heads. Unfortunaly my little reprap prusa mendel i2 hasn't the space for two printheads and i made some mistakes as i build it yust like the online documentary. So now my x axis roads a a little to short so my Printhead can't use the full size of the 20*20cm build platform.
Greetings
Janaha
Offline gildasd
  • Engineering watch officer - Apprentice Officer
    • Sci-fi Meanderings
« Reply #27 on: June 23, 2014, 11:04:20 am »
I've been looking at the video a few times...
It's brilliant, love it, want one, no budget, will have to wait, darn.
... I can see a lack of rigidity/damping when it moves side to side, it kinda annoys me.
You could use triangular 10/15cm stiffeners in each corner (relative to movement) simple screwed in.
It would probably help precision.
Being a cheap arse, it'd probably cut-up old/defect PCB to make them...
G.
I'm electronically illiterate
Offline SNGLinks
« Reply #28 on: June 25, 2014, 08:03:33 am »
The 1 inch frame parts, in the UK, were made by Dexion. It was called Speed Frame. Although Dexion went under some years ago, it's still available.
http://www.richardsonsuk.co.uk/Aluminium-Tubes/p47?gclid=CILV0_nHlL8CFQsEwwodj0cAsQ
Offline gildasd
« Reply #29 on: June 25, 2014, 08:45:01 am »
Checked it out,
Yeah, the junction parts are plastic... Great for damping but this this is going to need stiffeners or it will transform itself into a very expensive plastic life-cycle fatigue experiment.
