My first 'real' job was working for an Apple dealer when these were a current model.
The keyboard (and I think the mouse too) in the teardown is off a later model computer of the Classic / IIsi vintage. The regular keyboard for the Mac SE was functionally the same but bigger, heavier and chunkier with proper replaceable key switches.
I suspect that the plate stuck to the bottom of the Mac was for mounting the computer on a swing-out monitor arm. The arms were very popular in the late 80s and used all sorts of weird and wonderful mounting arrangements. I've also seen large stick on plates, without the four metal 'feet' used as a security device in University computer labs.
I was always nervous about pulling the plug on the logic board on these machines. The plug is right under the CRT neck board and if it was tight (usually the case), your hand could jerk upwards and hit the neck board. I've witnessed the destruction of a Mac CRT by that means. It's always wise to slip the neck board off first and give yourself a couple of extra centimetres.
Apple were notorious for embedding Easter Eggs in their ROMs. The photos of the developer team in the Mac SE ROMs were a well known one. There's some discussion on the background to the "Stolen from Apple" easter egg here:
http://folklore.org/StoryView.py?project=Macintosh&story=Stolen_From_Apple.txtOne of my favourite easter eggs was in the later model Mac LC. If you hit the programmer switch (actually the <Command> + <Power> buttons on the keyboard) at exactly the right time while the Mac was completing its power on self test, the Mac would "crash": it would emit a full volume screech of tyres, followed by a crash sound!
The SE was a fairly reliable / bullet proof machine - a big change from the earlier Plus which had reputation for developing all sorts of power supply and video faults.
