Hello,
I like the tl866, thanks for this tool.
Two issues though:
1) TL866 v6.10: The DALLAS
DS1245Y-120 NVRAM is
effectively NOT supported. When using the "supported DS1245Y" IC settings, garbage is read and garbage is written. I know because I did so once. Nasty bug, lost my cal data this way. One should always do plausability checks of the NVRAM content read.
==> Please correctly support this chip (DALLAS DS1245Y-120) ASAP. Thank you.
==> WORKAROUND (home-made adapter required): use IC "AM27F010" and reroute the differing pins. See also:
http://www1.tek.com/forum/viewtopic.php?f=5&t=6353AM28F0102) TL866 v6.10 and v6.16: A Macronix SPI flash
MX25L1605D may be read. When blanked the chip cannot be read from nor written to any more! The chip ID was once "0xC2 20 15" and is "0x00 00 00" after blanking, the TL866 is aborting with "Overcurrent protection.." after the first couple of seconds when programming is tried immediatel after blanking.
When waiting some time before reprogramming the MX25L1605D after blanking it, the programming procedure fails at the very last moment. Please see the attached screenshot.
Let me know if there are any questions. I'll be glad to help testing, too.
Your help is deeply appreciated. Thank you very much.
cheers,
om
PS: Dave, thanks for your awesome blog, keep going!
Edit: tested
MX25L1605D using v6.16: not working.
Edit2: clarified the tested software version/chip combination.
