600V caps are about the same price as 400v units, basically the same construction just a thicker oxide layer grown on the surface. The transistors in any case will be 1000V or 1200V units, so no cost difference. Copper losses will be the same, but the thinner wire used costs less, and the thinner board copper is cheaper and means you can have narrow traces on the same board as broad power traces.
