Author Topic: EEVblog #387 - Oscilloscope Trigger Jitter  (Read 2851 times)
Offline EEVblogTopic starter
« on: November 19, 2012, 10:48:24 am »
Dave.
Offline nixxon
  • Country: no
Re: EEVblog #387 - Oscilloscope Trigger Jitter
« Reply #1 on: November 19, 2012, 10:38:33 pm »
The first wave of the CH1 waveform seemed to have a tad higher voltage peak than the rest of the waves, so a possible 4th way to avoid major jitter could possibly be to increase the trigger level to just below 2.39 volts (4.78 Vpp/2).
This could be a solution if you use an old, analog scope without high tek standoff, pulsewidth stuff or if there were no sync pulse available.
