Author Topic: EEVblog #363 - Gold Phone Teardown  (Read 34427 times)
Online EEVblogTopic starter
« on: October 02, 2012, 10:47:47 pm »
Dave.
Offline steve30
    • Stephen Coates' Homepage
Re: EEVblog #363 - Gold Phone Teardown
« Reply #1 on: October 02, 2012, 11:52:25 pm »
Interesting.
Would be really cool if you could get it fully working :).
I wonder if all payphones use the same principle for detecting the coins or not. I rarely make telephone calls but when I used payphones years ago, I remember them always working, but when I came to use one about 3 years ago, there were lots of them around, but I struggled to find one that would actually accept my coins!
Offline N2IXK
« Reply #2 on: October 02, 2012, 11:53:36 pm »
Interesting teardown.
I believe the reason for the dual coils on the coin validator is a means of measuring not only the metal content, but the diameter of the coin, as well. As the coin rolls between the 2 coils, it acts like the core of a transformer, coupling a signal from one set of coils into the other. The length of the resulting output pulse would depend on the size of the coin, with a larger coin taking a longer time to roll past the coils, giving a longer output pulse.
"My favorite programming language is...SOLDER!"--Robert A. Pease
Offline krivx
  • Country: ie
« Reply #3 on: October 03, 2012, 02:45:20 am »
The sliding mechanisms to allow servicing aren't too surprising, I've seen the same thing in automated payment machines in multi-story carparks. Obviously these devices can be large and heavy and every minute out of service costs money, so they need to be repairable quickly in the field.
Offline Bored@Work
« Reply #4 on: October 03, 2012, 05:05:39 am »
These things were build and used at another time. Government-owned phone company, tenured government employees.
This wasn't about costing money when being out of service. This was about doing the right thing - in the minds of the government employees. Cost was the least of their worries. Providing the citizens with what a government phone company deemed adequate service, following laws and regulations was one goal (laws and regulations they typically heavily influenced). Not exposing government tenured workers to unduly stress and difficulties when having to service such a phone was another goal.
Offline notsob
« Reply #5 on: October 03, 2012, 05:35:59 am »
I knew someone involved in designing one of the public phone series - not the gold one.
They installed their test 'articles' in very rough city areas, to see what that local boys could do to the phones.
The eventual product had hardened steel cases to make it more difficult for them to drill holes into the phone (to access switches with probes), teflon coated wires in the flexible steel hand piece cable to stop destruction via cigarette lighters, teflon coatings in the coin slot to stop super glued coins, coin detector to check if it was a coin or a metal washer, chute to let sand thru (someone liked pouring sand into the units to break them), mounting bolts with 2" wide heads (some units were being ripped out of the phone booths with ropes tied to vehicles). the list goes on. The eventual phone killer that they couldn't stop was someone resorted to pouring coke into the phones via the coin slot.
So it is not only the electronics design and the mechanical design, it's making them vandal proof. (definitely s designers nightmare)
Offline firewalker
  • Country: gr
« Reply #6 on: October 03, 2012, 08:42:53 am »
So... No new Altium license?  :P :P :P
Alexander.
Offline muris
  • Country: ba
    • Elektronika
« Reply #7 on: October 03, 2012, 10:08:07 am »
Very interesting teardown, Dave!
I especially love the coin accepting mechanism, it intrigues me very very much. I wonder what the signals looks like through those coils and how fast does the micro-controller must "match" it to the pre-programmed values in order to accept or reject the coin on it's way down.
Best regards!
Offline madires
  • A qualified hobbyist ;)
« Reply #8 on: October 03, 2012, 11:53:39 am »
Dave might need to provide a dial tone, not just DC power.
Offline frenky
  • Country: si
    • Frenki.net
« Reply #9 on: October 03, 2012, 12:14:16 pm »
It could be rejecting coins because the cassette is not inserted and micro switch is in open position.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #10 on: October 03, 2012, 12:25:21 pm »
Same thoughts.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline steve30
« Reply #11 on: October 03, 2012, 02:41:55 pm »
Possibly.
Is there any reason why it shouldn't just be connected straight to a telephone line?
Also, just wondering, is the telephone's ringer a proper bell, or a speaker?
« Reply #12 on: October 03, 2012, 03:19:53 pm »
Public phones work off the standard -48V telephone supply, but need additional data delivered. One is a metering pulse of -60V applied between both lines and the earth connection of the phone. There is also a swap of line polarity when the call is connected to the other party, to tell the phone that billing has started and it must expect a billing pulse within a local unit time. If the pulse does not come and it is calling to a number not in the preprogrammed prefix table for freecall number blocks the phone will cut the call and go into tamper mode, where it disconnects, releases the line, tries to sieze the line then dials the self report number of the Telco and reports the tamper for repair. It will either stay in this mode and only receive calls, or will reset on the next successful meter pulse, depending on the programming.
Older call boxes had a much simpler mechanism, where coin data was transferred by pulses to earth when you put coins in the mechanism, which had a coil for each unit, and gave a pulse for each. Thus a 5c piece would give one pulse, a 10c 2 and a 20c 4. Even worked via an operator connected call, where the operator would listen to the clicks and count them then connect your call. Hard to fool the operator with a long tikkie, as there was a written called number record to grill. Automatic exchanges however could be fooled by wet toilet paper across the 3 wires, and dial a 0 to give 10 pulses.......... Or a 4k7 resistor on 2 croc clips, not that I ever did this, of course ;) ;D , though one box had a large count on the meter and 5c in the coin box............. One guy did a 11 hour call to his girlfriend, and the conversation from his side was " Ja liefie.............Nee Liefie.................Rerig liefie" ( Yes dear, no dear, really dear) for the 11 hours..............
Offline NewBeginner
« Reply #13 on: October 03, 2012, 03:46:20 pm »
Dave, it seems to me that, after all this time,  you still hold a grudge on Altium :). Move on my friend :)
Offline G7PSK
  • It is hot until proved not.
« Reply #14 on: October 03, 2012, 04:10:35 pm »
Would the reason that the phone did not accept the coins be that the cash drawer was not in place and holding down the micro switch, also are the coins today identical in all ways to the coins used when that phone was made. I have noticed that many older coins will not work in vending machines and that some vending machines will no take the latest coins due to dis similar metals and slight differences in weight or size.
Offline reagle
    • KuzyaTech
« Reply #15 on: October 07, 2012, 03:15:05 am »
As Dave was saying "Vandal Proof", I kept looking at the cable to the headset. That looked very easy to cut/rip. The phones I've dealt with in the former USSR, had a metal spiral like shroud covering the wires. Then the rotary disk would get melted, so they started using vandal proof metal keypads
« Reply #16 on: October 07, 2012, 05:28:08 am »
These were typically used inside a shop or such, where there is some supervision. The cutting of the cable would be noticed at least. Outdoor phones have the steel spiral wrapped cordsets here ( where you can still find one) and the locks have been upgraded to a very secure and very hard to damage style as well. Cabling is always in steel conduit as well, or buried in a plastic conduit under plaster. The phone booths have evolved from the old close door type to a GRP eggshell to the latest variants which are a steel column with a steel rooflet and a steel bar forming the side.
Offline T4P
  • Country: sg
    • T4P
« Reply #17 on: October 07, 2012, 06:57:09 am »
Basically what the engineers have been thinking, "Use steel where possible"
« Reply #18 on: October 07, 2012, 07:05:37 am »
Concrete takes too long to cure............ The railings on pedestrian walkways used to be aluminium, but it all grew legs. The buggers even stole the stainless steel fastenings off a bridge, causing it to collapse. For that I put the blame squarely on the contractors renovating it, as they are only accessible with a swing scaffold and hanging down 5m above a river known to have crocodiles.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #19 on: October 07, 2012, 01:09:14 pm »
ABBA - Ring Ring
iratus parum formica
« Reply #20 on: October 07, 2012, 01:54:37 pm »
Ed, you gotta find videos that are not restricted...........
Offline Ed.Kloonk
« Reply #21 on: October 07, 2012, 04:10:22 pm »
Err sorry didn't realise. What's wrong you cant see it?
« Reply #22 on: October 07, 2012, 05:12:13 pm »
Have to watch on YT, not embeddable in my country......... Nice side recommendations though.
Offline Ed.Kloonk
« Reply #23 on: October 08, 2012, 07:54:51 am »
No worries.
Offline reagle
    • KuzyaTech
« Reply #24 on: October 08, 2012, 04:21:25 pm »
Speaking of bastards taking bridge apart. How about somebody walking away with copper from a live HV transmission line? That's impressive :)
