Author Topic: EEVblog #306 - Jim Williams Pulse Generator  (Read 303076 times)
Offline HackedFridgeMagnet
Re: EEVblog #306 - Jim Williams Pulse Generator
« Reply #500 on: March 27, 2014, 06:43:18 am »
So you're saying at some unknown (to me) voltage, we could get a percentage of 2n2222s to avalanche in a similar way? Would they need to be some old batch do you think or any more modern 2n2222s could avalanche?
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #501 on: March 27, 2014, 09:46:58 am »
No need for such a poorly defined transistor (seriously, the world would be a better place if everyone forgot about 2N2222 and picked 2N4401 instead ;D ), it's been my experience that 2N3904 is avalanche capable.  Typically around 90-100V, with a 4.7k B-E resistor.
Seven Transistor Labs, LLC
Offline linux-works
    • netstuff
« Reply #502 on: March 28, 2014, 02:26:13 am »
I just saw this thread.  I'd like a kit, also ;)
I'm in the bay area, so if I can be of help, just ask.
Offline eurofox
    • Music
« Reply #503 on: April 12, 2014, 09:39:02 pm »
+1 In for a kit MKII version.
eurofox
eurofox
Offline kmel
« Reply #504 on: April 28, 2014, 08:03:00 pm »
+1 for a MKII kit
Offline joetorelli
« Reply #505 on: May 10, 2014, 03:21:40 am »
New to the EEVBLOG. I just found this forum ~3wks ago. I have been reading and watching this blog forum so much my wife thinks I am cheating on her, because I been doing nothing else. Except getting majors headaches from all the reading.
Anyway are these kits still being made? I went to ebay and could not find anything. And this subject seems to have faded off. If they are still being made count me in for a calibrated kit.
Thanks
Offline e-pirate
  • Country: ru
    • www.e-pirate.ru
« Reply #506 on: May 18, 2014, 04:51:52 pm »
Hi, folks!
I'm currently designing my own version of PCB for this avalanche pulse generator. This board will be placed in aluminum box. BNC connector is a PCB vertical thought hole connector that will be soldered to the board parallel. The 50 ohm resistor mounted vertically right under signal/central wire. This is me very first design of such type generators (and frequency), so I want to know what do you think about ground polygon distribution. I separated grounds of voltage source and the output part. Any ideas how to improve?
Oh, and there is a switch on the right side of the box.
« Last Edit: May 18, 2014, 04:54:39 pm by e-priest »
** Think, research, design, experiment, create..
Offline OldTech
« Reply #507 on: May 20, 2014, 06:39:35 am »
@free_electron,
Hope you are well soon.
I am interested in two calibrated Picosecond Pulser MK-II units.
OldTech
« Last Edit: May 20, 2014, 06:41:48 am by OldTech »
Offline EV
  • Aficionado
« Reply #508 on: May 20, 2014, 08:23:42 am »
You don't have delay line in your kit? The pulse will be very short and not flat. Look at pictures of reply 214 in this thread. There is delay line.
Hi, folks!
Offline e-pirate
  • Country: ru
    • www.e-pirate.ru
« Reply #509 on: May 20, 2014, 11:09:50 am »
Well, I don't know how to calculate wave guide  :-//
And I will probably combine ground polygons. I don't think there is a reason to separate them.
« Last Edit: May 20, 2014, 11:11:58 am by e-priest »
Offline han
« Reply #510 on: May 20, 2014, 11:18:06 am »
is there anyone ever try the impulse generator on Spectrum analyzer?
sorry if there already the answer in the 31 page before...
Offline c4757p
  • adieu
« Reply #511 on: May 20, 2014, 11:51:05 am »
Google seems to do well for "how to calculate waveguide"...
Agreed. Unless you have a real reason to force ground currents to be separate, you're just creating extra inductance, which may or may not be a problem for you.
I like it otherwise. Nice, compact design, even though it's PTH. Perhaps you could fit some length of delay line under the battery. Alternatively, use coax!
« Last Edit: May 20, 2014, 12:01:43 pm by c4757p »
Offline free_electron
    • SiliconValleyGarage
« Reply #512 on: May 20, 2014, 02:54:51 pm »
This project has been on the backburner a bit.
I will place an order for blank circuit boards this week.
Calibrated kits are bo longer available. I don't have access to the scope anymore.
Now, since we have a good sample spread from the original batch we know what these generators do in terms of rise time. So calibration is not really necessary
I am still in doubt what i should make available.
A) Board + 2 NOS transistors from the same batch.
B) Full kit including case
Board and transistors can be sent in a regular envelope. But , if everyone then has to start digging for all the other stuff .. Its time consuming and wont meet minimum shipping requirements from digikey or others.
Let me do a price calculation for the full kit. Parts prices may have fluctuated.
Offline alank2
« Reply #513 on: May 20, 2014, 03:18:06 pm »
Awesome news!  I'd prefer one with a case, but I'll take whatever is available and don't mind sourcing parts from digikey if needed.
Please keep us posted!
Offline gdewitte
« Reply #514 on: May 20, 2014, 04:58:23 pm »
+1 for the case kit.
Offline e-pirate
  • Country: ru
    • www.e-pirate.ru
« Reply #515 on: May 20, 2014, 06:56:26 pm »
Here is a new layout with a single ground polygon. I will search through Internet how to make a waveguide and probably design another version.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #516 on: May 20, 2014, 10:20:31 pm »
I think the name of Jim Williams ought to be on the board!
Jim Williams' avalanche (FAST) pulse generator (See Linear Technology AN47), or something like that, perhaps?
Offline Chris.M
« Reply #517 on: May 21, 2014, 12:43:37 am »
Could you please put me down for one Full kit including case.
Offline H.O
« Reply #518 on: May 21, 2014, 06:53:11 am »
Excellent news!
I'm (still) in for a kit, whichever you decide, thanks!
Offline e-pirate
  • Country: ru
    • www.e-pirate.ru
« Reply #519 on: May 21, 2014, 09:51:52 am »
Completely agree! Just in respect to Jim.
Offline fpliuzzi
« Reply #520 on: May 21, 2014, 11:35:28 am »
Thanks for making these available again. Please put me down for one full kit including the case.
(if you decide to just make the board and two transistors available, that would be fine too)
« Last Edit: May 23, 2014, 11:22:36 am by fpliuzzi »
Offline linux-works
    • netstuff
« Reply #521 on: May 21, 2014, 02:36:10 pm »
+1 kit for me, please.
Offline cyr
« Reply #522 on: May 21, 2014, 05:26:42 pm »
SA and scope below (with some external attenuation).
Note how the first null in the spectrum corresponds to 1 / pulse width.
Also, there is a rule of thumb that most of the frequency content of a square wave is below approximately 0.5 / rise time. That would be 2.5GHz for a 200ps edge, which looks about right.
« Last Edit: May 21, 2014, 05:32:54 pm by cyr »
Offline han
« Reply #523 on: May 23, 2014, 03:08:01 am »
Thanks for the effort. :D
i just remember the Fourier theory when i in univ
Offline idpromnut
« Reply #524 on: May 23, 2014, 09:31:58 am »
If the parts + case can be sourced via digikey then i am ok with just the board and transistors.
