Right. Here's a promised update:
Final design.
Deviation from the JW schematic : i use a CR2032 coincell and have two additionla 1-uf Ceramic caps around the LT1073.
The @n2369 is mounted Dead-bug style in a hole drilled in the PCB. The cae of this transsitor is electrically connected to the Collector. so the hole has the 1 Megaohm and 2pF caps connected to it. The collector wire is simply snipped of , or can be tacket to the rim of the case.
The base wire is bent outwards and down to land on an SMD pad to the 10k base resistor.
the 50 ohm resistor is made with two 100 ohms 1206 body resistors soldered back to back and vertically. A standard through hole SMA connector is put on edge and soldered on the board.
The emitter wire is bent out form the to-18 can and lies on top of the resistors electrode and contacts the center pin of the SMA. Two dabs of solder do the rest. The goal wa ot minimize stray capacitance as much as possible. I also opened the soldermask around the critical area's to avoid leakage there.
Copper features with soldermask removed :
The loop on the back is intentional. This is the feedback point of the voltage divider. I do not want that running underneath the switching inductor as it would pick up the field , so it 'detours'. that point is high impedant.
Everything fits in a Hammond case model 1553AABK or 1553AAGY. All the cutouts and mounting holes are present in the PCB.
All parts are available from digikey apart from the 2n2369.
I will order the PCB tomorrow from IteadStudio. I'll have a few extra's. If anyone is interested. 5$ gets you a blank PCB (US shipping included). I order the 10x5 cm as this board is 6.5 by 5. And go for the color version (i don't like green boards. I'm colorblind and don't see green. They are grey to me ... dull and drab. I may go with yellow soldermask and black text ... or Blue and white ). Shipping will be done to me from itead using UPS. I don't want to wait an unknown amount of weeks to get this.
I will probably order parts from digikey in quantity a well ( no point in buying 3 diodes.... ) So if anyone is interested in the full kit.
I have to calculate what the final would be. I have 2n2369 plenty. I'll throw in 2 or 3 per kit.
