Author Topic: EEVblog #306 - Jim Williams Pulse Generator  (Read 300847 times)
Offline carpelux
Re: EEVblog #306 - Jim Williams Pulse Generator
« Reply #350 on: May 07, 2013, 08:44:50 pm »
Thanks a lot!
Catch the light
Offline jpb
« Reply #351 on: May 07, 2013, 09:05:26 pm »
I received my kits yesterday.  Thank you!
I built one up this morning and put it on my fastest [working] scope, a Tektronix MSO3034.   Photo attached.
I'm looking forward to getting my kit. It seems to produce fairly accurate bandwidth measurements on scopes in the 100MHz to 500MHz range.
Your measurements are for a rise of 7 times. The tau of the pulse generator is around 200psecs for 20% to 80% or 4 times so for 7 times I think this would increase to (ln(7)/ln(4))*200psecs or around 280 psecs so the net rise from your measurements is around sqrt(980^2-280^2)psecs or 940 psecs.
The Bandwidth is then approximately (ln(7)/2.pi)/940psecs = 0.31/940psecs = 330MHz which is 10% up on the nominal 300MHz.
All very believable.
Offline EV
  • Aficionado
« Reply #352 on: May 07, 2013, 09:33:01 pm »
  Photo attached.
Risetimes marked.  :)
Offline John_L
« Reply #353 on: May 09, 2013, 09:15:08 am »
Thanks Vince
Offline jpb
« Reply #354 on: May 09, 2013, 10:41:28 am »
Is it ok to connect the pulser straight to the 50ohm input of an oscilloscope rated at 5Vrms (for 50 ohms)?
I have a WaveJet and the specs don't list a peak voltage for 50 ohms, just the rms value of 5V and I guess that though the peak voltage for the pulser is 10V it only lasts 5nsecs and the duty cycle is low. (What is the duty cycle?)
I haven't got my kit yet but I don't possess any attenuators at present and was wondering whether to get a set (they are quite pricey).
Offline EV
  • Aficionado
« Reply #355 on: May 09, 2013, 02:17:36 pm »
I think that there is no problem. My Tektronix TDS3032 has max 5 VRMS with peaks < ±30 V. Problem was that the max vertical division is 1V/div. That is why the pulse can not be seen completely without attenautor. With attenautor the uppper side of the pulse is not horisontal. Look at my earlier post:
https://www.eevblog.com/forum/blog/eevblog-306-jim-williams-pulse-generator/300/
Offline free_electron
    • SiliconValleyGarage
« Reply #356 on: May 09, 2013, 02:44:19 pm »
It depends on the scope ... It will definitely clip the signal.
I had the same problem when doing the measurement. I used a real divide by two attenuator during the test.
The attenuator is 50 ohms both ways. Meaning it is 50 ohms towards the pulse generator and also matches the 50 ohms of the scope. (Plus we 'calibrated' the attenuator away.)
Offline EV
  • Aficionado
« Reply #357 on: May 13, 2013, 10:16:03 am »
I have got now 6 dB attenuator. It is much better than that 20 dB attenuator which I used earlier. The upper side of the pulse is much nearer horisontal line now. I have ordered also 3 dB attenuator which is probably still better and with it the whole pulse can also be seen.
Offline jpb
« Reply #358 on: May 13, 2013, 10:48:14 am »
I guess I'll go with an attenuator to be safe.
The WaveJet that I have states that 5Vrms is a maximum for the 50ohm input but it goes up to 2V/div on 50ohms so presumably can show 16Vp-p so should be able to show a 10V pulse without clipping (I'm assuming that you can apply an offset of around -5V.)
SMA attenuators appear to be much higher frequency than BNC ones (18GHz vs 1 or 2GHz) for the same sort of price but I guess it makes little difference as the SMA to BNC adapter is probably only good to a GHz and my scope is 350MHz anyway.
(Hameg do a reasonably priced set of 4 attenuators and a 50ohm pass through rated at 1W and  1GHz with BNC connectors designed for their scopes.)
« Reply #359 on: May 13, 2013, 01:53:00 pm »
Anyone not received his pulsegen yet ?
(Apart from the last 8 buyers. Those leave today or tomorrow. I packcaged them over the weekend)
Offline fmaimon
  • Country: br
« Reply #360 on: May 13, 2013, 03:01:02 pm »
As I'm on vacations, I won't know for another 2 weeks, but I wouldn't be surprised if i still havn't arrived, as the Brazilian Post and customs are very slow... As soon as I get home I'll check.
Offline w2aew
    • My YouTube Channel
« Reply #361 on: May 14, 2013, 10:25:00 pm »
OK, here are my results from pulse tester #6 (thanks Scotto!).  First is the result using my old Tektronix 2467 which is a 350MHz analog scope.  Cursors are on the approximate 10-90% points.  The next two images are using a homebrew 20dB attenuator (which may slightly slow the results), on a 1GHz Tektronix MDO4104-6 and on a Tektronix 8GHz MSO70804C.
FAE for Tektronix
Offline hgg
  • Country: gr
« Reply #362 on: May 15, 2013, 06:45:02 am »
free_electron, hi !
Can I have a calibrated one as well ??  Do you sell them assembled?
What is the total cost to Greece?
« Reply #363 on: May 15, 2013, 11:43:18 am »
W2aew, I think the scope is the limiting factor here...........
Hgg, I think Vince does have some left, you will have to PM him to see.
Offline jpb
« Reply #364 on: May 15, 2013, 11:51:11 am »
That is true for the first two, but not for the 8GHz scope.
Vince's measurements gave rise times for 20% to 80% whilst W2aew's are for 10% to 90% so will be (ln(9)/ln(4)) times as long approximately (at least that would be the case for a simple exponential type rise as with a Gaussian filter - I'm not so sure about the case for maximally flat input responses as in higher frequency scopes).
So 234psecs for 10% to 90% would correspond to only around 148psecs for 20% to 80%.
« Last Edit: May 15, 2013, 11:53:47 am by jpb »
Offline EV
  • Aficionado
« Reply #365 on: May 15, 2013, 11:59:32 am »
W2aew, fine scopes and pictures!  :P
Offline hgg
  • Country: gr
« Reply #366 on: May 15, 2013, 01:54:26 pm »
Thanks SeanB, I will.
Offline BravoV
  • +++ ATH1
« Reply #367 on: May 17, 2013, 05:29:52 am »
I will post the final cal screenshots this weekend. Last batch goes out the door tomorrow. Fmaimon was in the last batch.(last week)
I'll post an updat tonight. Everything os put the door. There are kits and cals left and a few bare boards as welll. How many ... I need to cou t em.
Ah yes. I will post the other screenshots today.
Shameless bump.  >:D
« Reply #368 on: May 17, 2013, 01:44:43 pm »
I need one of three things :
- invent time travel
- clone myself so there's two of me
- days of 48 hours ...
I'll try posting the rest tonoght.
Offline AlfBaz
« Reply #369 on: May 17, 2013, 02:13:30 pm »
Gees you're a wimp, there's at least another 8 hours you are wasting with sleep! :)
Offline Teneyes
« Reply #370 on: May 17, 2013, 02:16:24 pm »
Be Nice
Be Positive to catch more Free Electrons
IiIiIiIiIi  --  curiosity killed the cat but, satisfaction brought it back
« Last Edit: May 19, 2013, 03:58:51 pm by free_electron »
Offline c4757p
  • adieu
« Reply #372 on: May 19, 2013, 05:56:43 pm »
Have you mailed these yet?
Offline Teneyes
« Reply #373 on: May 19, 2013, 06:27:11 pm »
@BravoV
  Will you be nitpicking about the Standard deviation in the values of Risetimes of Free's workmanship ::)
Offline JimmyMz
« Reply #374 on: May 19, 2013, 09:08:42 pm »
Free_Electron, you have a PM.  :)
If you didn't get this message, let me know, and I'll get you another.
