Author Topic: EEVblog #304 - Mailbag  (Read 8978 times)
Offline tntTopic starter
« on: July 04, 2012, 11:44:35 pm »
Hi Dave,
Glad you like the pulse generator :) A few comments :
I put the design files are available here http://people.osmocom.org/tnt/hw/pulse_gen/ , the only mod is the addition of the CC-BY-SA license on PCB.
I didn't put a battery holder directly there because I wanted to mount everything in a tube and the the battery would fit "inline" with the PCB.
Concerning the connector yes, the other type would have been useful for scope testing but it's not easy to find good ones and I had a good BNC female / BNC female adaptor handy ... Also if you want to use it to test cables (Time Domain Reflectometry), it's not an issue if you have the right kind of BNC tee.
The appnote explain what you can tweak, there is also two through holes to connect a long coax (hard line) if you want to have the pulse last longer. Since my scope was only 350 MHz, I couldn't really see what difference several transistors made ... if you have better scope you might be able to compare to locally source transistors ...
PS: Hey, I've seen in the youtube comments some fellow "Louvaniste" (people from Louvain La Neuve where I live) and even from FSA / EPL as well it seems (school of applied sciences at the UCL university I attended).
PPS: btw: "Munaut" is pronounced "Mun" as in "MUNich"  and "aut" as in "HOse" (at least that's the closest match I can think of at 1am :)
Offline krivx
  • Country: ie
Re: EEVblog #304 - Mailbag
« Reply #1 on: July 04, 2012, 11:56:01 pm »
Do you have any rise-time measurements for this build? Or should I wait for Dave's video? :)
Offline EEVblog
« Reply #2 on: July 05, 2012, 01:16:02 am »
Video uploading now. Although of course my scope is only 500MHz, so can't give a true value.
I tried to find a local scope somewhere to do it, but was out of luck.
Agilent have said they'll loan me a $100K scope which should do the job  :o
Dave.
Offline dda
« Reply #3 on: July 05, 2012, 01:22:04 am »
I was worried about the long thin package after you had opened the first.
Offline T4P
  • Country: sg
    • T4P
« Reply #4 on: July 05, 2012, 02:24:28 am »
That time when i got my digital calliper ( the same one you recieved )
it came okay ... somebody must be having a bad day
Offline PeteInTexas
« Reply #5 on: July 05, 2012, 05:30:11 am »
Yeah me too.  I was imagining the "bodgy" electronics it may have had. ;D
Offline free_electron
    • SiliconValleyGarage
« Reply #6 on: July 05, 2012, 06:05:31 am »
i just watched the mailbag thing. hilarious. ladies wear...
you can change the motto to  :
'Don't get turned on ... take it off'
now  :D
Offline David_AVD
« Reply #7 on: July 05, 2012, 06:27:04 am »
So the construction may have been somewhat "dicky" eh?  LOL
Offline peter.mitchell
« Reply #8 on: July 05, 2012, 07:42:22 am »
hmmm...
now to start shipping random electronics from china to dave, just to see if they're useful to him.
EDIT: ordered some small boards, see how they perform for size and simplicity, im sure you could find something useful to use with them.
EDIT 2: forgot to change my shipping address back so i guess you can check out how dodgy the protection circuit is on a cheap chinese phone battery maybe even its rated capacity.
« Last Edit: July 06, 2012, 07:19:50 am by peter.mitchell »
Offline nitro2k01
« Reply #9 on: July 05, 2012, 10:30:24 am »
That meter... Plug it into the wall in ohms mode. You know you want to.
jucole
  • Guest
« Reply #10 on: July 05, 2012, 03:17:33 pm »
Hi,  some info which might be of some use to someone regarding digital caliper bus signals.
http://www.shumatech.com/support/chinese_scales.htm
Regards
Offline Pat Pending
« Reply #11 on: July 05, 2012, 04:03:19 pm »
So much bubble wrap and still a smashed LCD glass ??
Offline Monkeh
« Reply #12 on: July 05, 2012, 06:27:12 pm »
There wasn't any seperation of items inside the bubble wrap.
Offline LaurenceW
    • It's Time, Jim, but not as we know it
« Reply #13 on: July 05, 2012, 07:18:49 pm »
Dave, looking at the impedances around the avalanche transistor - pretty high. When you touch the transistor (collector) with your paw, you are providing a low impedance to ground (BNC shell), so THAT's why the oscillations die, I reckon.
If you don't measure, you don't get.
