Author Topic: EEVblog #334 - History of PDA Teardowns  (Read 20605 times)
Offline EEVblogTopic starter
« on: August 14, 2012, 11:14:07 pm »
Dave.
Offline cloudscapes
Re: EEVblog #334 - History of PDA Teardowns
« Reply #1 on: August 15, 2012, 01:15:44 am »
Could the ADC on the ninties PDA be for the resistive touch LCD? 1 meg sample/s is overkill for that obviously, but I can't imagine what else it could be for.
Offline oPossum
« Reply #2 on: August 15, 2012, 08:37:12 am »
The black marks on the PCB are resistors - probably pullup resistors because the value is not critical.
Many 68xx parts require a quadrature clock, so the xtal is 4x the clock freq to make generating the quadrature clock easy. It probably is running at 921.6 kHz. Most of the older 68xx series parts where 2 MHz max for the B suffix parts.
Offline Ed.Kloonk
  • Cat video aficionado
« Reply #3 on: August 15, 2012, 09:32:08 am »
Giving it a thumbs up!  :)
iratus parum formica
Offline nitro2k01
« Reply #4 on: August 15, 2012, 09:50:08 am »
I was thinking the same, but I have my doubts. I have seen this done inside a Super Nintendo controller, which made sense since it was already using carbon (I guess it is?) for the button pads. However in this case I there are two reasons why I doubt the are pullup resistors.
1) If the board isn't using the carbon coating for anything else, is/wasn't it expensive to introduce a new process, compared to placing resistors with a pick and place machine?
2) With that short distance and thickness, it seems like the resistance would be too low for a typical pull resistor.
(If it's a pull resistor, it's a pulldown and not up btw. You can see at 13:20 how they're connected to the same trace that the crystal capacitors are connected to as well, most likely gnd.)
Offline TradieTrev
« Reply #5 on: August 15, 2012, 10:45:57 am »
Good stuff Dave! I really appreciated the last HP ipaq number.
Fond memories around '05 with fellow electricians purchasing second hand ipaq's for the purpose of gps. At the time gps navigators had highly inflated prices. The cheapest alternative was to purchase a cheap pda with gps and load cracked navigation software from some random torrent site! Worked a treat for several years!
Still consider today my very first purchase of a smart phone the hp ipaq hw6965; It was really the pinnacle to the smart phone evolution. So many technologies rolled into one.
With the ever evolution of smart phones & system on a chips solutions it's expect smart phones to comprise of a chip, board, battery & touch screen! I couldn't imagine your average electronics guru building one in the back shed  ;)
Offline SteveyG
  • Soldering Equipment Guru
« Reply #6 on: August 15, 2012, 11:50:49 am »
Don't know what Dave's on about regarding the HD44780 LCD driver in this video. Every LCD I come across with a HD44780 compatible interface has at least two chips on it.  ???
The iPaq had a Ni-MH rechargeable battery in it rather than a primary cell for keeping the contents of the SRAM. If you didn't charge the iPaq for a week, it'd lose all of your installed applications!
« Last Edit: August 15, 2012, 12:11:11 pm by SteveyG »
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline freddyk
« Reply #7 on: August 15, 2012, 12:31:00 pm »
The black lines does seem to be printed resistors. I opened up my two remaining Psion devices (models XP and LZ64) and found one with the black marks and one with regular SMT resistors.
The printed ones at the top in the first image measured between 120k - 160k.
/Fredrik
« Reply #8 on: August 15, 2012, 01:45:19 pm »
I didn't take a good look at mine. They looked for all the world like visual NP marks, so I just moved on.
It just didn't make sense to do the extra carbon step when they could have just placed the resistors.
I'll have to measure mine to confirm, but it does seem they are.
Dave.
Online IanB
« Reply #9 on: August 15, 2012, 02:51:11 pm »
Fascinating how BIG the iPAQ is! All that circuitry and board area for the wi-fi, the GPS and then the main board as well.
It would be really interesting to compare that with, say, an iPhone 4, where the wi-fi, the GPS, the 3G, the GSM, the main CPU and more besides all fits into about 3 sq in of board area. How did it get shrunk down so much?
« Reply #10 on: August 15, 2012, 03:36:30 pm »
Screen printing the resistors probably saved a lot of time on the pick and place machine, or they had a limited set of part carriers and needed to run the board through in a single pass. A single silk screen mask saves a hundred picks.
Offline T4P
  • Country: sg
    • T4P
« Reply #11 on: August 15, 2012, 04:08:49 pm »
Due to consumers ... engineers get clever along with very very high density ASIC's the size of your thumb and flash densities so deep if you were to emulate it with through hole parts, you would need the entire earth
Offline Eliminateur
  • Country: ar
  • Electronic's Technician
« Reply #12 on: August 15, 2012, 04:19:27 pm »
Dave,
SiRF is a very popular chipset nowadays for GPS, the latest gen the sirfstar 5 is a monster SoC, can track gps(a-gps, beacon), gnss, galileo, compass, integrates MEMS etc
the one normally used the III is pretty capable, tracks 20 sats at once(i think the standard is usually up to 12).
btw: "motoloa" must be the new Hawaian CPU manufacturer :P
Offline firewalker
  • Country: gr
« Reply #13 on: August 15, 2012, 05:38:37 pm »
This is really bad. Once I had to repair several portable printers with such a design. When a page was being print the movement of the heads was transmitted to the crystal and it was sorting some pins on the processor, "freezing" the printing process.
Alexander.
« Last Edit: August 15, 2012, 05:41:38 pm by firewalker »
Offline Eliminateur
  • Country: ar
« Reply #14 on: August 15, 2012, 05:49:19 pm »
Also, i'm amazed at how much logic was needed for a lousy mobile 802.11b wifi module!
there's 4 TXCs alone!, that huge processor, the baseband, several front-ends/amps, horrible!
nowadays you get 802.11b/g/n (and probably more than 1 antenna) all in a single chip or at most 2 chips, the baseband the the processor
Offline Bored@Work
« Reply #15 on: August 15, 2012, 06:39:24 pm »
Try to do it with a bag of transistors ...
« Reply #16 on: August 15, 2012, 06:53:25 pm »
Firewalker, that crystal is glued down to the board though.
Offline firewalker
  • Country: gr
« Reply #17 on: August 15, 2012, 06:57:44 pm »
Yes, I know. The ones in the printers was glued too. For a while at least.
Alexander.
Offline sonicj
  • updata successed!
« Reply #18 on: August 16, 2012, 05:34:14 am »
I'm still using a old Palm Vx to monitor various parameters on my electric golf cart. Amps, Volts, Watthours, Temp, etc. All values can be logged to the device for graphing or analysis or whatever. RS-232 straight out of the motor controller and into the Palm. Purdy handy!
Software including source can be downloaded here: AXEmon by Steve Sawtelle
Offline T4P
  • Country: sg
    • T4P
« Reply #19 on: August 16, 2012, 01:46:05 pm »
Well for one nobody though of integration yet, there wasn't any need to highly integrate everything together
Offline Eliminateur
  • Country: ar
« Reply #20 on: August 16, 2012, 02:21:45 pm »
Also, it surprised me seeing an Atmel IC on it, i never knew Atmel had something to do with wifi at some point(they bailed quickly it seems)
Offline swabaxter
« Reply #21 on: June 19, 2014, 12:33:10 pm »
Dave,
The iPAQ line was originally made by COMPAQ and was rebranded HP after they bought the company.
You said in the video iPAQ was a Palm line - maybe a slip of the tongue.
My first PDA was a Psion II followed by a couple of Psion 3s. Then I switched to Palm M500
and also had a Dell running Windows CE at the same time.
Regards,
Stephen
Offline bigfun
« Reply #22 on: October 01, 2015, 04:59:54 pm »
that spider you found in that one PDA was actually just a shed skin from a spider.  if you'd put it under a microscope you would have seen it was like an eight-legged trousers.
