Thanks, Ian. Good advice.
I switched the breadboard, thinking that might be the problem, too. Here's what I have.
Building the circuit on page 2, using a constant 5V input and varying the voltage on pin 5, I can get the full range in bar- and dot-modes and everything works as it should. I know that everything is ok, I haven't blown the chip, etc. etc.
My problem seems to stem from trying to measure the voltage of the cell (or cells, or power supply) that is actually powering the circuit, and this is what I'm not understanding. As I power the entire circuit (and pin 5) from lower voltage, then I always have Pin 10 LED lit indicating that the voltage is at the maximum. This makes sense to me, in that the voltage I'm measuring is exactly the same as the voltage that is supplying the circuit - therefore I have "full" voltage. If I use a voltage divider, I could see how I could get different results, because I'm dividing the measured voltage from the working voltage of the circuit.
I guess I'm at a loss to understand how I can measure the power supply voltage when that same power supply voltage is powering everything - won't it always see pin 5 input as maximum? I suppose I need to go back to Dave's video again, too, and refresh.
Any thoughts? Hopefully I'm missing something very basic here, but I just don't see how you can measure a voltage level and show it as a percentage of full when the entire circuit sees the same voltage.
john
