National Semiconductor (Texas Instruments) LM3914, similar circuit is often found in the voltmeter/current meter displaying the brightness of microscope lamp house, LED bar graph like in the Olympus BH-2 and I am not sure about the Olympus BX series. The newer microscopes did away with this LED bar graph denoting lamp house light bulb brightness. My Olympus CX31RBSF does not have this LED bar graph lamp voltage. We have seen some audio equipment with this LED audio volume voltmeter bar graph display in stereo recorders and amplifiers in the 1980s, past.
The data sheet is available on the web or pdf, today. Ten years ago, it was either on a text book, data sheet book from NSC (National Semiconductor Corporation), electronics instructions book like Don Lancaster, "TTL Cookbook." TTL, transistor-transistor logic was very modern and people did earn good money implementing it around San Jose in the 1970s, the microcomputer and integrated circuit boom era. I was too young then, but was fascinated reading about the new products, possibilities, and prosperity at the time.
http://www.national.com/mpf/LM/LM3914.html#OverviewThe battery tester instructions or bar graph voltmeters are in the book by Delton T. Horn, "Low Cost Test Equipment Projects You Can Build."
http://www.amazon.com/Low-Cost-Test-Equipment-Projects-Build/dp/0830641556Thanks for showing the breadboard LM3914 set up, Dave Jones. The wiring trace is simple, that I would like to etch my own board at home with mask tape and etch chemicals. I will have to drill my own holes for the single sided through the hole components to populate the printed circuit board.
