Author Topic: eevBLAB 120 - DCS sues Youtuber for Defamation! - Threatens entire review indust  (Read 1119 times)
Online EEVblogTopic starter
A small Australian company called Deep Cycle Systems (DCS) is suing Youtuber Stephan Fischer from AllOffroad 4x4 Adventures for defamation for (IMO) an honest multi-year battery review and documenting other users  experiences with DCS LFP batteries in their 4x4 vehicles.
If DCS win this insane lawsuit it will be a threat to the entire review industry, everyone will lose.
https://www.youtube.com/@UC825uQNChjLwDQC7B3yZdoQ
GoFundMe: https://www.gofundme.com/f/help-fight-for-truth-in-youtube-reviews
https://www.patreon.com/alloffroad
Defamation lawsuit playlist: https://www.youtube.com/playlist?list=PLA2XSq4ONOVJB3uj0xsjcZiGAS1Nd8skV
The two review videos he's being sued for:
The Australian government have tested DCS LFP home storage batteries:
https://arena.gov.au/projects/testing-the-performance-of-lithium-ion-batteries/
Report is here: https://arena.gov.au/assets/2018/05/lithium-ion-battery-testing-public-report-12.pdf
There is some precedent for defamation by companies against individuals in Australia:
https://www.austlii.edu.au/au/journals/CommsLawB/2020/14.pdf
https://gclegal.com.au/limelight-newsletters/defaming-through-google-reviews/
Defamation act 2005: https://legislation.nsw.gov.au/view/whole/html/inforce/current/act-2005-077
The battery capacity tester discussed:
https://www.amazon.com.au/MakerHawk-Adjustable-Electronic-Intelligent-Resistance/dp/B07F3NHHST
Deep Cycle System website:
https://www.deepcyclesystems.com.au/
https://www.deepcyclesystems.com.au/dcs-battery-tech/
Reviews: https://www.productreview.com.au/listings/deep-cycle-systems-dcs
Other videos discussing the DCS lawsuit:
Louis Rossman: https://www.youtube.com/results?search_query=louis+rossmann+dcs
John Cadogan:
4x4 Adventures:
Online dietert1
  • Country: br
    • CADT Homepage
After watching one of the videos i thought about the 1.5 % accuracy claim in battery capacity measurements. Doing this measurement in a two wire scheme can yield systematically low results, as the 10 A test current can certainly cause a voltage drop of 0.5 V or so, that is already 4 % of 12 V. I didn't notice any four wire setup in the video.
Legally it may not be enough to assume Ah and Wh is the same.
Regards, Dieter
« Last Edit: August 09, 2024, 10:31:30 am by dietert1 »
Online mikeselectricstuff
    • Mike's Electric Stuff
Wonder if they're also going to sue all the people leaving reviews here
Interesting one here suggests maybe they're a 1-man-band importer
- That SW upgrade only possible at owners private address in the Brisbane hills, no car parking.
Day Job: Mostly LEDs
In the testing video instruction Stephan mentions to run capacity tester until the BMS inside the battery itself does the voltage detection and shutoff.
This means that 4-wire testing is irrelevant, as the capacity tester is just essentially a constant current load, timer, and calculator.
So seems a legit test to me.
Offline snoopy
    • Analog Precision
What's with the DCS brand lately because another unrelated dCS tried to sue another youtube reviewer recently for a negative review but the rally cry and negative publicity made them eat humble pie in the end ;)
https://www.audiosciencereview.com/forum/index.php?threads/dcs-threatens-with-a-7-figure-lawsuit-over-a-review.55729/
« Last Edit: August 09, 2024, 11:53:42 am by snoopy »
Offline madires
  • A qualified hobbyist ;)
Did DCS book the all-inclusive Streisand effect full experience package? >:D
A saw that in my search and had to watch it before I figured out it was th same DCS!
The super delux package option!
The following users thanked this post: MK14
Offline 3roomlab
Online dietert1
  • Country: br
    • CADT Homepage
Please note that these tests labeled "Australian Government" and "Australian Renewable Energy Agency" are executed by a company named ITP in Canberra. Still missing is a serious comparison to lead-acid battery storage. One of the remarks in Stephan Fischers video was "going back to lead-acid". ITP reports describe problems while testing lead-acid battery storage, but i didn't find numbers on capacity fading.
We have to be aware that everything made public in this field may be worth millions. In my opinion any result that can't be verified shouldn't be trusted.
Regards, Dieter
« Last Edit: August 10, 2024, 09:21:56 am by dietert1 »
wow this batt test docu is really telling
And it sounds like they tried their best to compensate and extract the most energy they could.
Who set up a battery test facility based on the government funding. And the data is officially republished by the government.
In fact the test result data doesn't seem to be available through the companies website, only via the government portal.
So it very fair to say it's "government testing" IMO.
https://itpau.com.au/knowledge/itps-battery-test-centre/
« Last Edit: August 11, 2024, 10:37:36 pm by EEVblog »
Offline thm_w
  • Non-expert
Regards, Dieter
Kind of two separate issues here. The going back to lead acid part is only talking about the 12V under-hood lead acid battery. I wouldn't be surprised if the DCS battery is still better than a lead acid.
And he could always run some wires to re-locate the battery to an area of the truck that is not so hot. I'd take LFP over lead-acid any day in terms of reliability. Even it meant some extra work.
The following users thanked this post: petrinch
Online dietert1
  • Country: br
    • CADT Homepage
Looking at the BYD battery test diagram shown above, it's interesting that the storage capacity increased. Of course it didn't increase physically but they introduced another mode of operation or another mode of measurement that works better. Probably those technologies are still in a pioneering stage.
The photovoltaic generators that we built in 2008 will also need a storage system when the government guarantees expire in 2028.
Regards, Dieter
