in many cases protocol problems stem from problems in the analog domain.
In my experience, it's "most"
And that's the problem with logic analysers, they can't show that. They only work on electrically robust systems. The first thing I do when troubleshooting a digital system is to use a scope to eliminate any signal integrity issues.
This is where there is a disconnect. A scope is fine for the 'basic' slow interfaces - I2C, SPI, serial etc. (although as I said the decoders can be buggy, for instance the Siglent SDS1202X-E doesn't get the stop bit settings right on simple async serial - unless they've fixed that with an update by now). To be fair, these are the ones that are more likely to be 'casually' implemented and so suffer more signal integrity issues.
There's a difference between these types of interfaces and 'big boy' interfaces like high speed parallel video busses, DDR3 etc. where you have to pretty much guarantee signal integrity by design. It's one thing to 'coo' over the cute length matched traces, it's quite another to actually have to design that stuff. Both ends disappear under BGA packages, and you can't afford the stubs caused by test headers, you have to align traces, leave a rectangular solder mask window and use Mictor probes. My personal logic analyser is a 34 channel Agilent, 250MHz timing, with 100k 1.5pF probes - and that's nowhere near current crop, it's around 25 years old. Try putting your x10 passive scope probes on those signals and see what happens - at very best, you'll be looking at the signal integrity that you just trashed. Of course you can buy 4 very expensive active probes, but they will cost more than the scope. With luck, you
might get away with custom Z0 probes (effectively what the LA probes are). The best you can do in signal integrity terms (apart from designing it right in the first place) is to wind down the thresholds to below the IC worst case input specs and look for reflections.
Anyway, leaving aside logic analysers, it's the effect of "WHY sell 2CH Oscilloscopes?" type videos that worries me. The very obvious answer is that there is a market for them. Looking around, I can get a Rigol DS1102Z-E for reasonable £250 in the UK, a pretty good deal compared to a short buffer buggy Hantek. A DS1054Z on the other hand can be had for about £350 - now that's not just £100 difference, it's also a 40% more. You can go on more or less indefinitely, adding £50-100 more to get this or that model with a 'must have' fancy feature. It's a honey trap for beginners [Edit: "best bang-per-buck" doesn't cover it, it should be 'how many bucks do they
need to spend'].
It's probably fair to say that the viewership of your videos is heavily slewed towards beginners (not your fault). It worries me when, particularly over recent months, I've seen a number of beginner scope threads where the OP's 'entry level' shopping list consists of various 2Gsample and/or 12 bit (and yes, 4 channel) models, because that's all they see you getting excited about in recent videos. I wonder how many of them will spend £500 on a scope, play around unsuccessfully with some 555s and opamps on a breadboard, get disillusioned and stuff it in a cupboard, together with their fancy AWG and other stuff. Maybe the 20MHz bandwidth filters should be enabled by factory default.
Bottom line, maybe it's time to start putting out some videos on bargain scopes and equipment that will suit beginners, get them through the first couple of years of learning, playing with basic stuff, Arduinos etc. (maybe a lot of them will never need to go past that stage), and see if they're actually going to stick with the hobby. Either that, or start putting a 'parental warning' saying that beginners really don't need this level of stuff, save your money. I think there's a danger of disconnect with your actual (versus target) audience.
