Author Topic: EEVblog 1630 - Solar Panels for Water Pre-Heating?  (Read 243 times)
Online EEVblogTopic starter
« on: Yesterday at 08:24:09 am »
Is it worthwhile to run water through your solar panels to cool them down while pre-heating your hot water? Also solar air and water heaters.
Answering a Twitter question:
https://x.com/axion2003/status/1812740667367460971
As always, YMMV.
Offline nctnico
Re: EEVblog 1630 - Solar Panels for Water Pre-Heating?
« Reply #1 on: Yesterday at 08:35:46 am »
Looks complicated indeed. I have been wondering about installing a water mist system (which basically are a few plastic pipes which run under the panels) to cool the panels using tap water and up the production of the panels on a hot day. It could make a difference of 50W per panel.
« Last Edit: Yesterday at 08:42:12 am by nctnico »
« Reply #2 on: Yesterday at 12:06:03 pm »
Cheaper and simpler to just install a few more panels to compensate?
Bonus in that you get more output on cooler days.
K.I.S.S
Offline nctnico
« Reply #3 on: Yesterday at 02:34:03 pm »
K.I.S.S
That only works if you have space left on the roof. An advantage of a misting system could be that the interior of the house doesn't get so warm so the AC has less work to do. But I didn't run any numbers on the amount of water (cost) is needed.
« Last Edit: Yesterday at 02:36:52 pm by nctnico »
Online BarrowBoy
« Reply #4 on: Yesterday at 03:03:21 pm »
Lack of roof space....bifacial solar modules?
