Author Topic: EEVblog 1624 - Electronex: Liquid Instruments Moku Oscilloscope  (Read 1270 times)
Online EEVblogTopic starter
An interview at the Liquid Instruments stand at Electronex 2024 about the Moku range of multi-function mixed signal oscilloscope, designed and built in Australia!
Thanks to Ben Price for answering the questions even though he's the mechnical engineer!
https://www.liquidinstruments.com/
The following users thanked this post: SeanB, egonotto
Offline egonotto
Re: EEVblog 1624 - Electronex: Liquid Instruments Moku Oscilloscope
« Reply #1 on: June 25, 2024, 11:02:07 pm »
Hello,
I am a little disappointed by the specs of the analog inputs.
Moku:Pro:
Bandwidth (-3 dB)  300 MHz / 600 MHz switchable
Sampling rate  5 GSa/s with 1 channel, and 1.25 GSa/s with 4 channels
Resolution  10 bits
Noise: 300 / 400 uV RMS at 400 mVpp (if my guess is reasonably correct)
Memory: Deep memory captures > 60 million samples (Logic Analyser has  262k × 16 input sample depth and up to 32,764 x 16 output sample depth)
Best regards
egonotto
Best regards
egonotto
Online SiliconWizard
« Reply #2 on: June 26, 2024, 06:30:13 am »
Specs are on par with the standalone oscilloscopes in this range.
The Pro version is a bit expensive, but packs a lot of features. It's an Australian company, so you can't expect chinese prices. And they seem to be doing a great job.
The following users thanked this post: thm_w, mairo
Online nctnico
« Reply #3 on: June 27, 2024, 06:00:17 pm »
Actually the product is more on par with the Analog Discovery. Unfortunately the specifications are severely lacking details. Things like input ranges/sensitivities (if these are even adjustable?) are missing. The 'datasheets' are what I would call a short form brochure. A datasheet should enable people to make a technical purchase decission but this is not possible with what is provided for the Moku devices.
« Last Edit: June 27, 2024, 06:08:45 pm by nctnico »
Offline schmitt trigger
  • Country: mx
« Reply #4 on: June 27, 2024, 06:56:16 pm »
I am suitably impressed with the available instrument suite.
Sure, its bandwidth is a little on the shy side.
The GUI appears to be extremely intuitive, a must for an instrument with so many capabilities.
And nowadays, where it appears that every instrumentation breakthrough announcement comes from a Chinese company, it is refreshing to see someone else coming up with smartly designed devices.
Offline thm_w
  • Non-expert
« Reply #5 on: July 02, 2024, 07:56:14 pm »
The Go doesn't have a full spec sheet yet, but you can see in the datasheet its rated +/-25V:
https://download.liquidinstruments.com/documentation/datasheet/hardware/mokugo/Datasheet-MokuGo.pdf?hsCtaTracking=cec2661c-6a14-4fc0-9d2e-3bbb3eb8a5ab%7C750e3b5a-33dc-497a-bd5a-b1c4f10a4da8
If you look at the Lab there is a full spec sheet:
https://3954510.fs1.hubspotusercontent-na1.net/hubfs/3954510/_Internal/Gated%20Content/Datasheets%20and%20PDFs/MokuLab-Specifications.pdf?utm_referrer=https%3A%2F%2Fwww.liquidinstruments.com%2Fproducts%2Fhardware-platforms%2Fmokulab%2F
https://download.liquidinstruments.com/documentation/datasheet/hardware/mokulab/Datasheet-MokuLab.pdf
Analog in ranges: +/-1V or +/-10V.
So the Go is probably one 25V range.
As mentioned in the comments/video, these are designed for laser research labs, where it sounds like you just need low voltage inputs.
« Reply #6 on: July 04, 2024, 05:19:44 am »
Yeah, niche market, not a general purpose scope.
Offline WokeJordon
  • Country: cn
    • DONGMING MOTOR
« Reply #7 on: July 09, 2024, 07:28:30 am »
Good.
woke Jordon
DONGMING MOTOR
