Surprising to see that current clamp on the 50Hz mains input for presumably the AC trigger (or would that be on the PSU daughterboard). Wouldn't a current coil give a current instead of voltage trigger? (Or is my sleep deprivation making me think that
How would they guarantee that the power factor (correction) of the main PSU is predictable and constant? And wouldn't the PFC (slightly) change depending on the load on the PSU?
So what would happen if you change the screen brightness or use a high power device from the USB ports? Or the mains voltage changes? How low would the jitter/accuracy be?
Maybe something interesting to test because intuitively I would have my doubts whether probing the current waveform would really give that stable of a 50Hz trigger source.
Other than that the design looks great.
Also surprising choice to see 2 "scopes on a chip" that are then combined together with presumably 1 FPGA. That FPGA would have to do at least some extra lifting to put a display frame together on the screen with GUI around it, but also handle the framebuffers of each individual intensity graded waveform (+LA +SA?), The position & draw order can all change, so it would have to handle that all in hardware too.
