Author Topic: EEVblog 1445 - How to Simulate an Oscilloscope Probe in LTSPICE  (Read 8317 times)
Offline EEVblogTopic starter
« on: December 21, 2021, 09:42:30 pm »
How to simulate a x1 oscilloscope probe in LTSPICE.
And how to use the lossy transmission line model in practice with the spice directive.
Mysteries of x1 oscilloscope probes revealed:
Offline radioing
  • Country: cz
Re: EEVblog 1445 - How to Simulate an Oscilloscope Probe in LTSPICE
« Reply #1 on: December 23, 2021, 08:13:34 pm »
Hello Dave, thank you for nice video - good point with the Spice DC setting by big R to enable synthesis of 'floating' circuits.
Several years ago I found the Joe Weber's >100 pages document about
Tektronix osc. probes design from 1969 - 'Oscilloscope Probe Circuits'.
Not sure you saw/read it but anyway, even it's a little bit ancient, the theory holds and it's nice reading for anybody who's interested in.
The following users thanked this post: tstp
« Reply #2 on: December 23, 2021, 11:27:12 pm »
I haven't seen that, is there a PDF available?
Offline Tom45
« Reply #3 on: December 24, 2021, 12:17:45 am »
Search for TekProbeCircuits.pdf
It can be found at a number of places.
Offline David Hess
  • DavidH
« Reply #4 on: December 24, 2021, 01:39:41 am »
Oscilloscope probes are actually tested and specified with a 25 ohm source impedance from a parallel terminated 50 ohm source.  The probe tip adapter used for testing is driven from a 50 ohm generator and has a 50 ohm parallel termination built into it directly at the probe tip, like a 50 ohm feedthrough terminator.  So your bandwidth results are only half of what they should be.
Is there a PDF available.  Sheesh, only on days ending in "Y": (1)
https://w140.com/tekwiki/images/6/62/062-1146-00.pdf
(1) Yankee humor.
The following users thanked this post: EEVblog
Offline DL4JY
« Reply #5 on: January 24, 2022, 11:07:47 pm »
Hi Dave,
when watching your video, I was a bit struggling with the assumption of having a 50 Ohm cable. I recall when I tried to repair a broken cable of a probe many years ago, that the inner conductor was thin as a hair. This would rather give an impedance of 120 Ohms or so.  (~0.1mm inner conductor, ~2mm outer conductor). I believe they use this higher impedance cable to decrease overall capacitance, especially in the 10:1 mode.
This would change the values a bit. The capacitance of the 1.2m cable would be more like 50pF and the inductance 730nH. Together with the compensation capacitor & a bit of stray capacitance we come into the direction of your measured value.
How much this will change your simulation, I have no working spice currently. But I tried unsuccessfully to use a VNA/Distance-to-Fault measurement with one of my probes with a potentiometer at the end - to adjust to the line impedance, but no luck - it was almost no difference what I connected to the other end. And yes , I was in the 1:1 position.
thanks for the great video & best regards from the other side were its now cold & wet.
Juergen
Offline shapirus
  • Country: ua
« Reply #6 on: April 22, 2024, 10:09:39 am »
An idea for a future video: simulation of a 10x probe.
