Author Topic: What's the keywords for finding a yellow spudger like Dave has?  (Read 3808 times)
Offline ballsystemlordTopic starter
Hello,
I tried searching on ebay and aliexpress, but I can't seem to figure out what the correct keywords are. I'd like a set of 10 identical ones if possible.
What I have found are blue and orange ones. Yuck, it must be yellow!  ;)
Thanks!
Offline Kim Christensen
Re: What's the keywords for finding a yellow spudger like Dave has?
« Reply #1 on: May 02, 2024, 03:24:18 am »
Why don't you post a screen grab of Dave using his yellow spudger... Maybe someone will recognize it.
Offline bdunham7
« Reply #2 on: May 02, 2024, 04:20:12 am »
Have you tried "yellow spudger" ?
« Reply #3 on: May 02, 2024, 12:28:35 pm »
As requested, here's a picture. I don't think I've ever seen the full thing, just that end.
I'd feel really stupid if I hadn't tried that. That being said, sometimes these search engines can be finicky. You can search for the exact item number and not get results until you give the search engine a bigger hint.
Online kripton2035
« Reply #4 on: May 02, 2024, 12:34:33 pm »
I've found the green ones ...
https://www.aliexpress.com/item/1005005322005276.html
you can also choose your color by making your own ...
https://www.thingiverse.com/thing:5205171/files
« Last Edit: May 02, 2024, 12:38:49 pm by kripton2035 »
Offline bdunham7
Offline aeberbach
Software guy studying B.Eng.
« Reply #7 on: May 03, 2024, 01:26:06 am »
@bdunham7 That is the physical form of the item. And certainly, the keyword "yellow" is in the description. But if you take the picture and put a yellow and an orange line next to them you can clearly see that these are not yellow.
That's CSS orange and yellow that I'm using. It has nothing to do with my palette or program that I'm using to "paint" with.
« Last Edit: May 03, 2024, 01:28:20 am by ballsystemlord »
Offline Brumby
« Reply #8 on: May 03, 2024, 06:45:35 am »
You could be making a fundamental mistake here.
Firstly, a lot of eBay photos are not properly illuminated, let alone correctly white balanced.  Yellow things looking orange is an easy thing to do.  Have a look at the last photo of the set and you will clearly see a yellow colour.  It does have an orange fringe, but that is what happens with poorly lit yellow items.
I have found that accurate colour on eBay is the exception, not the rule.  See here for more info on such photography:
Re: How-to make decent photographs for forum posts/articles/publications?
« Last Edit: May 03, 2024, 10:39:53 am by Brumby »
The following users thanked this post: ballsystemlord
