Author Topic: EEVblog 1574 - Is the $42 Fluke 101 Multimeter Any Good?  (Read 10015 times)
Offline EEVblogTopic starter
« on: October 27, 2023, 02:27:09 am »
Is a $42 Fluke multimeter any good? The Fluke 101 reviewed.
The following users thanked this post: SeanB, pdenisowski
Offline tchicago
Re: EEVblog 1574 - Is the $42 Fluke 101 Multimeter Any Good?
« Reply #1 on: October 27, 2023, 05:01:07 am »
Interesting effect: it measures about 0.3V when banged with a hammer or a hand.
Apparently, some element generates an electricity due to a segnetoelectric effect.
That means this device cannot be used on a vibrating vehicle, like a train or airplane.
Offline Kleinstein
« Reply #2 on: October 27, 2023, 08:24:33 am »
I would not be so sure about having averaring AC response. Some of the modern DMM chips sets include RMS as digital true RMS, though with a limited bandwidth.
It may be worth testing if it is true RMS and maybe also the frequency range (e.g. does it cover the audio range).
The calibration seal can be circumvented by opening the case - there seem to be no seal on the srews.
Offline G0MJW
  • Mike
    • G0MJW
« Reply #3 on: October 27, 2023, 12:24:33 pm »
It's good for $42, but it is nearly double that price in Europe so not such a good deal.
Mike
Offline Gyro
« Reply #4 on: October 27, 2023, 12:35:33 pm »
Currently £57 in the UK.
Best Regards, Chris
Online joeqsmith
« Reply #5 on: October 27, 2023, 06:01:49 pm »
Online The Soulman
  • The sky is the limit!
« Reply #6 on: October 27, 2023, 06:09:57 pm »
Joe, was the input shorted on your vibration test?
Online joeqsmith
« Reply #7 on: October 27, 2023, 06:14:18 pm »
Well, yes and no.  I consider my smacking the meter with my hand part of the vibration test.  During the initial beat down, the inputs were floating.  Then I added a jumper for further beatings and the vibration table.  Assuming person trying to read volts on their jet aircraft have a low impedance source.
Online joeqsmith
« Reply #8 on: October 27, 2023, 06:43:47 pm »
As far as battery life for the 101,  I measured 840 hrs typical.
For the switch cycle testing, I never ran the 101.  It was that Fluke 17B+ that performed so well, while the brand new Fluke 87V had some damage to pads where the wiper contacts had cut groves into them.   You would think the 87V would have outperformed the 17B+ but maybe with it being such an old design, they never improved it where the 17B+ was starting from a clean slate.
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #9 on: October 27, 2023, 06:46:35 pm »
(sigh) Now I have to go check if there's a room in the house that doesn't have it's own dedicated meter yet so I can justify buying one of these :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
« Reply #10 on: October 27, 2023, 06:54:48 pm »
Would assume one of the ceramic chip capacitors on the input or ADC are the cause of it. Ceramic cheaper than a film capacitor, which would nave not shown this, though you would run into issues with needing to glue down the film capacitor to the board to prevent the leads breaking off with vibration and time. Or use physically larger capacitors, and use better quality NPO types that are less prone to piezoelectric effects every place where it is on the input or ADC side, and not just supply bulk capacitors.
Online Bud
« Reply #11 on: October 27, 2023, 07:29:45 pm »
One should be nuts to use this class multimeter on a train or airplane.
Online Bud
« Reply #12 on: October 27, 2023, 07:32:37 pm »
Kudos to Fluke for the solid socket terminals. The ones on the Aneng are total garbage made out of paper thin spring sheet metal.
« Reply #13 on: October 28, 2023, 06:15:48 am »
I get about 30-50mV when I rub my hand on the LCD. It's not impact/vibration related.
« Reply #14 on: October 28, 2023, 06:18:37 am »
That's what would be expected based on my measurements.
Offline tchicago
« Reply #15 on: October 28, 2023, 06:56:41 am »
On Dave's video at 3:27 - it shows 0.3V AC.
And about 0.17V around 3:20.
Online joeqsmith
« Reply #16 on: October 28, 2023, 12:58:27 pm »
You do realize that the meter was floating?  Similar to the people who ask about returning their brand new meters after they turn them on with the leads floating and they don't see 0V.
If I rub my finger on the display with nothing attached to the meter, I see roughly that same 50mV error.    If measure a 5.0VAC signal and then rub my finger on the display, it appears to have no effect.   This is different than the Gossen Ultra (Prime now) where you have it attached to a low impedance source and the meter is still sensitive to moving your hands near it.  How this meter ever made it on the market with such poor shielding is anyones guess.
Offline Fungus
« Reply #17 on: October 28, 2023, 01:12:15 pm »
You can buy them on Aliexpress.
Offline Fungus
« Reply #18 on: October 28, 2023, 01:24:15 pm »
Joe Smith zapped his 101 with 17kV. It's one of the toughest Flukes he's tested. I think Fluke doesn't give it a higher rating for marketing reasons, not because it can't take it.
Fluke's web page used to describe them as "Extremely Rugged" but they've toned down the language now.
I figure the probe sockets are on the bottom because the shrouds on those TL75 leads are longer than the thickness of the meter.
Mine lives in a little zip case with some much smaller probes. Those Fluke probes are huge (and very long).
« Last Edit: October 28, 2023, 01:30:11 pm by Fungus »
Offline Fungus
« Reply #19 on: October 28, 2023, 01:38:56 pm »
Note to future owners: They're Loctite'd to their screws really hard and you don't have to remove them to get the PCB out.  :popcorn:
The following users thanked this post: EEVblog
Online joeqsmith
« Reply #20 on: October 28, 2023, 02:35:20 pm »
Close.  The Fluke 101 survived 12kV, 50us FWHH, 2 ohm source.    I took the Fluke 107 to 14kV 100us FWHH and it survived.
https://docs.google.com/spreadsheets/d/1cXzYpIoyVm9QJUju4KXqM22CEQZP3_xwWvDyeVwxTy4/edit#gid=400910915
Online joeqsmith
« Reply #21 on: October 28, 2023, 02:53:04 pm »
As far as the stand/hanger, I wonder if Dave's was lost.  Mine has a compartment to hold it inside of the shipping box.  I've never had it out until now.   It does have a magnet if you use it for a hanger.
Added a few more photos to show how it can be folded up to raise the meter to clear the leads.
« Last Edit: October 28, 2023, 03:03:03 pm by joeqsmith »
The following users thanked this post: EEVblog, oPossum, pdenisowski
Online bdunham7
« Reply #22 on: October 28, 2023, 04:20:38 pm »
Have you tried beating your other meters with a hammer (with no leads inserted) to see what they do?
Offline descartes
« Reply #23 on: October 30, 2023, 10:48:14 pm »
As well as a handy second meter on the desk, mine gets good use out & about resolving battery issues when I'm told "sure, we put in fresh batteries" - no arguments with a yellow meter's reading it seems.
« Reply #24 on: October 31, 2023, 12:20:43 am »
Mine has the compartment but there was nothing in it. I wondered what the compartment was for!
That certainly adds value.
