Teardown of the new $389 12bit Rigol DHO800 oscilloscope!
00:00 - Rigol's NEW $389 DHO800 12 bit Oscilloscope!
02:43 - USB-C Powered
03:19 - Teardown of the Small Sparrow, and the DHO900
06:39 - Heatsink Removed and cost reduction
08:01 - Is the USB-C connector robust enough?
11:25 - Plastic moulding
12:13 - Back side of PCB
12:48 - PCB Comparison with HDO1000
13:56 - The ADC
15:13 - What is the missing memory?
15:42 - BOM cost INCREASE? Why?
16:40 - Bypass caps WTF. Madman Muntz is turning in his grave!
17:42 - Front end comparison with DHO1000 and HDO4000
20:00 - The Logic Analyser
21:15 - The Arbitrary Waveform Generator option in the DHO900
22:39 - PCB summary, and Dave doesn't allow this type of production engineering!
22:31 - Serial boot dumping
25:56 - The boot Android O/S micro SD card
27:15 - Power consumption and summary
