Strangely, this video has the biggest thumbs down ratio of all my recent videos except the LK99 one.
Are people pissed off they can't buy it?, or don't like projects?
I don't get it. It's my most requested video, and countless people cite the uSupply design series as one of the best things on my channel.
I loved the video.
Especially the part about using a digipot (or alternatives like using DAC and opamps) for switchmode voltage (and current!) control definitely deserves its own video, if you ever feel like doing one. I mean, even hobbyists like myself can nowadays use TI Webench to get good suggestions on chips and circuits to use, but to adapt one for digital control is "black magic". (I only know enough to know that the loop size, actual bandwidth of the digipot or opamp, and capacitance and inductance in the feedback loop, will affect the stability and functioning of the switchmode controller.)
A particular example I have, is to digitally adjust a boost controller from 5V to 7V-12V, to control three-pin voltage-controlled fans. (I've recently showed my PWM fan controller designs using ATtiny85, but I also have a bunch of pretty good 3-pin voltage-controlled ones with tachometer output.) The three-pin fans can be controlled by PWMing their 12V supply just fine, although one may need to adjust the frequency and add some filtering to avoid additional noise. The step-up-based one would allow efficient use of 5V USB wall-warts. (My ATtiny85 ones do not simply control the PWM or duty cycle based on user control; the user controls the fan RPM directly, with the ATtiny85 managing the duty cycle as needed, to get the fan to that speed. The purpose is to basically let the user control the airflow directly, even when the fan ages. Not a common need by any means, but very useful for the rare cases you do want/need one.)
