Author Topic: EEVblog 1545 - World's Fastest Oscilloscope, MXO4 TEARDOWN  (Read 13711 times)
Online EEVblogTopic starter
The following users thanked this post: egonotto, Fgrir, Rich@RohdeScopesUSA, pdenisowski, Martin72, mawyatt, Detlev
Offline YurkshireLad
Re: EEVblog 1545 - World's Fastest Oscilloscope, MXO4 TEARDOWN
« Reply #1 on: May 25, 2023, 01:48:46 am »
When I first read the title, I thought it said "world's fastest teardown". Doh!
The following users thanked this post: boB
Online SiliconWizard
« Reply #2 on: May 25, 2023, 02:04:24 am »
Great engineering! :-+
The following users thanked this post: pdenisowski
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
« Reply #3 on: May 25, 2023, 11:49:23 am »
I've had an MXO4 longer than almost anyone and I learned a lot from that video :)  Great stuff!
And I also completely understand the joy in cutting through a "Calibration Void if Broken" sticker ...
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
Online nctnico
« Reply #4 on: May 25, 2023, 12:00:49 pm »
Nice! A bit surprising that the MXO4 uses off-the-shelve ADCs. Didn't expect that but if they do the job for the right price then why not.
Offline TheSteve
  • Living the Dream
« Reply #5 on: May 25, 2023, 03:10:59 pm »
It certainly was pretty inside. The only negative I really noticed was if you wanted to clean the dust off the fan - quite the disassembly required. Maybe R&S wants to trade one for my modified 1 GHz MSOX3024t. There aren't many things I'd trade my special scope for, but this is one of them.
VE7FM
Offline Fgrir
« Reply #6 on: May 25, 2023, 04:59:56 pm »
Minor nitpick, but at 16:51 and 22:20 you circle 1K resistors and call them 1M.
But yeah, great teardown.  I need to find a project to justify this scope now.
Offline globoy
« Reply #7 on: May 25, 2023, 05:04:06 pm »
This might be a naive question (I'm no metrologist) but does the 200 MHz version have entirely different electronics?  I ask because the price for the ADC and ZINQ chips from distribution are very pricey (at least in low qty) and more than the list price of that version of the scope.  Otherwise R&S must be getting a helluva price on those chips.
Offline Kleinstein
« Reply #8 on: May 25, 2023, 05:20:16 pm »
Given that they still give the same 5 GS/s sampling rate the ADC is likely the same, maybe a slightly more noisy bin / grade.
For the ZINQ chip kind of has to be the same or they would need separate firmware.
The digikey price for such special parts with an expected downward trend in the price are rather inflated.
So R&S will earn way less money from the 200 MHz version - though it is still not a cheap scope.
Online nctnico
« Reply #9 on: May 25, 2023, 05:23:40 pm »
You can get hefty discounts from Xilinx if you register the project and Xilinx deems you worthy.
Offline globoy
« Reply #10 on: May 25, 2023, 05:32:33 pm »
Thanks.  If it is all the same electronics then one does wonder about hacking the 200 MHz version :-)
« Reply #11 on: May 25, 2023, 07:52:44 pm »
Yes, and it's also obvious that they don't pay the ADCs 3000 bucks each.
Online Martin72
  • Testfield Technician
« Reply #12 on: May 25, 2023, 11:24:02 pm »
After the teardown Dave needed a cigarette I guess.. ;)
Beautiful inside...This is building quality at it´s best, fron this point of view, the scope´s entry-price is cheap.
You can upgrade the 200Mhz up to 1.5Ghz just via license key, so the hardware is the same.
Buy the 200Mhz "cheapo" and hack it to 1.5Ghz.. 8)
(Kierkegaard)
The following users thanked this post: thm_w, globoy
Offline boB
    • my work www
« Reply #13 on: May 25, 2023, 11:34:30 pm »
« Last Edit: May 25, 2023, 11:36:48 pm by boB »
K7IQ
« Reply #14 on: May 26, 2023, 04:21:39 am »
Of course, but it's still funny.
« Reply #15 on: May 26, 2023, 05:54:32 am »
Yes, you gotta wonder who is ever going to buy these at this price, so why bother displaying them in the catalog? ;D
(If you're going to make prototypes you're probably still not going to buy them through this channel.)
Offline pdenisowski
« Reply #16 on: May 26, 2023, 10:32:39 am »
Isn't this scope faster than the MX04 ?
https://www.keysight.com/us/en/product/UXR1004A/infiniium-uxr-series-oscilloscope-100-ghz-4-channels.html
I thought that was the one you were talking about when I saw the title.
"Fastest" means "highest waveform update rate" (number of waveforms per second that can be acquired and displayed).  By that measure, the MXO4 is an order of magnitude faster than the UXR.
A lot of people think that sampling rate = speed but don't realize that most scopes actually discard a very large percentage of the samples they acquire and thus are "blind" most of the time.
I did an entire video (which has also been turned into a whitepaper) on this topic:
A loose analogy:  a "fast" or "high speed" camera is one that acquires and stores a large number of frames per second, not one that has a very high number of pixels per frame.
The following users thanked this post: EEVblog, boB, Detlev
Offline pdenisowski
« Reply #17 on: May 26, 2023, 10:38:20 am »
From Keysight's own whitepaper on the topic :)
"Waveform update rate can be extremely important when evaluating oscilloscopes for purchase. Although this specification is often overlooked, it can have a direct impact on your ability to capture a random and infrequent event which occurs just once in a million occurrences of your signal. There are three reasons why fast update rates are important for today’s oscilloscopes"
https://www.keysight.com/us/en/assets/7018-01745/white-papers/5989-7885.pdf
« Last Edit: May 26, 2023, 10:48:54 am by pdenisowski »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #18 on: May 27, 2023, 01:39:58 pm »
isnt fastest means "the highest fart count in a day"? it was in the dictionary of the future right?
Offline Fungus
« Reply #19 on: May 27, 2023, 06:12:33 pm »
How much would it cost to manufacture a PCB of that size/complexity with that many components on it?
(I mean just pure manufacturing costs, ignoring the price of the components)
Offline boB
    • my work www
« Reply #20 on: May 27, 2023, 06:21:06 pm »
I would still like to see the insides of a one $million dollar scope.
Compared to $8000, there must be something interesting in there.
boB
K7IQ
Offline Detlev
« Reply #21 on: May 27, 2023, 06:30:14 pm »
boB
https://youtu.be/DXYje2B04xE
« Last Edit: May 27, 2023, 06:34:27 pm by Detlev »
This post is "Made in Germany" 😎
Online nctnico
« Reply #22 on: May 27, 2023, 09:00:26 pm »
In volume: probably around $100 to $200 for placement costs. You'll only be paying for time needed by a P&P machine and it is not like the board is filled to the brim with components. The board is mostly green.
Offline julian1
« Reply #23 on: May 27, 2023, 09:07:36 pm »
The bga footprints have exposed bottom-layer pads for probing. And in places, there are two traces routed between each pad.
Offline boB
    • my work www
« Reply #24 on: May 27, 2023, 10:01:29 pm »
I guess it depends on your interpretation of "fast" then.   Evidently Keysight themselves said this....
"Keysight has introduced what is claims is the world’s fastest oscilloscope, operating at 256Gsample/s on signals up to 110GHz."
So, I guess you could take that either way.
I would think that rise and fall time might also be a factor that determines what you call faster or slower
boB
K7IQ
