Author Topic: EEVblog 1533 - How To Estimate Product Battery Life  (Read 2125 times)
Offline EEVblogTopic starter
« on: March 09, 2023, 10:30:32 pm »
How to estimate the battery life of a product. In this example, the BM786 multimeter.
How to measure battery current accurately, avoiding Burden voltage, and looking at battery datasheets characteristic curves. The difference between alkaline and lithium primary batteries.
The following users thanked this post: pdenisowski, 5U4GB
Offline pdenisowski
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
Re: EEVblog 1533 - How To Estimate Product Battery Life
« Reply #1 on: March 10, 2023, 10:54:05 am »
In my experience, a lot of engineering students and young engineers don't appreciate and/or don't understand the importance of battery life testing -- despite the fact that so much of their world actually runs on batteries -- so this is a very timely and useful video.  Thanks!
(and nice power supply :))
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: EEVblog
Online Kleinstein
« Reply #2 on: March 10, 2023, 12:37:38 pm »
Even with alkaline cells there is not that much energy left at low voltage. If one would want to use a alkaline cell to a lower voltage one may need 1 more cell. In the current example 4 cells would allow 0.9 V per cell to get the same final 3.6 drop out point, but one kind of wastes the energy from 1 more cell.  So the 1.2 V final voltage is not such a bad choice.
With a linear regulator and a fixed min voltage getting the ideal final voltage is a little similar to the maximum power point of a solar cell. Depending on the voltage chosen one gets a different capacity / current and there is a point of maximum power / energy.
Going at least down to 1.2 V allows to use NiMH or NiCd cell.
This gets very anoying when the drop out is higher (e.g. 1.4 V in some cases  :( ).
Extrapolating to lower current draw is relatively easy, as the low currents the batteries are usually well bahaved. So there is a capacity for low currents and than a drop at the higher current end.
So for the 5 mA load using 2 times the time for 10 mA load is a good approximation. So no need to really extrapolate the curve.
Offline f4eru
    • Chargehanger
« Reply #3 on: March 10, 2023, 09:14:36 pm »
What? no use nor mention of the uCurrent, while explaining burden voltage ?
I'm afraid I can't let you omit that dave  :D
Offline thm_w
  • Non-expert
« Reply #4 on: March 10, 2023, 09:59:39 pm »
It was there, you must have mentally blocked it out.
Offline SiliconWizard
« Reply #5 on: March 11, 2023, 12:37:15 am »
He even talked about the "low burden" 121GW, so promotion for two items. ;D
Offline mwb1100
« Reply #6 on: March 11, 2023, 02:07:51 am »
Of course there's also the star of the show, the BM786!  I've got one, and love it.
Even if 120-150 hours of battery life isn't stellar (Fluke claims 400 hours for the 87v on one 9V), 3 AAA's cost less than a buck so I'll manage.
