Author Topic: EEVblog 1528 - R&S MXO4 12bit Oscilloscope Unboxing and Experiments  (Read 8402 times)
Offline EEVblogTopic starter
Re: EEVblog 1528 - R&S MXO4 12bit Oscilloscope Unboxing and Experiments
« Reply #25 on: February 15, 2023, 01:30:30 am »
The fastest update rate appears to be at about 20 ns/div.  Your image show faster a faster timebase.  Set to 20 ns/div and you should get about 4.5M wfms/s.
Yep, 4.5M on 20ns/div only. All other above and below are lower.
Not sure if setting the waveform colors to temperature impacts update rate.  it may take more processing for this.  I used the simple yellow (requires factory default/preset) to change the color back to default.
Nope, same.
Online tszaboo
« Reply #26 on: February 15, 2023, 10:51:33 pm »
It's a seriously cool oscilloscope, I don't see anything that I didn't like.
I'm off to write an email to my boss why the current scope isn't good enough  :-DD Fat chance.
Offline Hydrawerk
« Reply #27 on: February 15, 2023, 10:52:12 pm »
« Reply #28 on: February 16, 2023, 12:59:55 am »
Betcha they have an infinite rental budget though. Capex is always a hard no.
Offline CRTbrain
« Reply #29 on: February 17, 2023, 06:49:32 pm »
Their overall serial bus coverage is a bit sparse at the moment.  Hoping this fills out...for engineers who need to work across a wide verity of buses.
Offline David Hess
  • DavidH
« Reply #30 on: April 07, 2023, 03:03:10 pm »
The MXO 4 series is tempting because of its performance, but I am currently looking for a DSO which can display the FFT magnitude and phase of a differentiated waveform for impulse response testing, and the MXO4 can do neither according to its documentation.  Older LeCroy and Tektronix DSOs support this and I may end up going with one of them.
« Last Edit: April 07, 2023, 03:06:08 pm by David Hess »
