Author Topic: EEVblog 1525 - Commisioned Mailbag  (Read 2499 times)
Online EEVblogTopic starter
« on: January 20, 2023, 10:14:49 pm »
00:00 - Comissioned component artwork
https://www.bad-dog-designs.co.uk/
01:48 - 1.3GHz DIY FET probe
https://hackaday.io/project/184924-diy-13-ghz-fet-probe
https://github.com/makerprobe/FETProbe_tiny
07:53 - The uSupply makes an apperance!
09:14 - Ron Demcko sends in some goodies
14:23 - Mysterious Patent
19:10 - USB Power Injector Crowd Supply kit
https://www.crowdsupply.com/board-outline
21:25 - Elimo Engineering electronic business card
https://elimo.io/
23:29 - Ambit Infusion Pump Teardown
30:20 - Metrawatt M2037 Multimeter Teardown
The following users thanked this post: golden_labels
Offline golden_labels
Re: EEVblog 1525 - Commisioned Mailbag
« Reply #1 on: January 21, 2023, 06:36:44 am »
The capacitors reel should bear the “inhalation hazard” warning! ;) During the middle ages, people were disputing how many devils can dance on the head of a pin. This is 2023 and the question should be brought back: how many bacteria cells can fit on a single SMD capacitor? ;)
I wonder, who is the target industry for such small sizes. SoC with ceramic substrates?
« Last Edit: January 21, 2023, 06:39:30 am by golden_labels »
People imagine AI as T1000. What we got so far is glorified T9.
Offline Kleinstein
« Reply #2 on: January 21, 2023, 12:43:17 pm »
Maxim did quite a lot ADC chips for the early DMMs (ICL71xx variants). Chances are they were 2nd source for intersil and they also had some extra ones for higher resolution. They also have newer ones, including some based on sigma-delta.
Because of the age I doubt this would be a sigma delta, more like a dual slope or kind of simple multi-slope (like the old LD120 and related). For a classic dual slope I am missing the usually relatively bulky integration cap (e.g. 100-500 nF PP type). There are 3 foil capacitors around, but they look a bit small for an ICL7135 or similar, clould still work for a faster running one (e.g. similar to max132)  to get a fast bar graph.
The relays in the DMM are likely for the current ranges, maybe for the highest voltage (e.g. >200 V). Chances are the set of diodes and transistors are for driving the coils for the relays.
The following users thanked this post: EEVblog
Offline 8086
    • Circuitology - Electronics Assembly
« Reply #3 on: January 21, 2023, 02:07:22 pm »
The business card is an electronic die, a tic-tac-toe game, and a Simon game  :) Selectable using the power/mode button.
https://elimo.io/ttt
