Author Topic: EEVblog 1520 - Troubleshooting a Faulty BM786 Multimeter  (Read 17962 times)
Offline EEVblogTopic starter
« on: December 20, 2022, 06:17:23 am »
Looking at a faulty returned BM786 multimeter.
Warning: Some components were harmed in the making of this video.
Offline bob808
Re: EEVblog 1520 - Troubleshooting a Faulty BM786 Multimeter
« Reply #1 on: December 21, 2022, 02:06:25 am »
That might be a possible short from manufacturing. Seems to be under the pins.
edit: nah, looked again at other frames and seems like it is gunk that you scraped earlier.
also can the micro pull it's own rails high? shouldn't the on signal come from some other chip/circuit?
there was also another rail that was coming through an inductor, can't remember if you measured that. if the enable for the rail doesn't happen there might be other stuff that's not enabled.
« Last Edit: December 21, 2022, 02:29:31 am by bob808 »
Offline joeqsmith
« Reply #2 on: December 21, 2022, 05:34:41 am »
Best two shots I saw of it.  Maybe damaged during the testing or maybe fine and just looks like the back was blown off.
Offer stands.  If you would like the Keysight for parts to repair yours I'll swap you.
Someone had posted a link to a better view of U2.   Looks fine.
« Last Edit: December 21, 2022, 01:38:08 pm by joeqsmith »
Offline bob808
« Reply #3 on: December 21, 2022, 11:53:57 am »
Had another look at the video and I don't see you measuring the other rail (photo 1).
Also the line (photo 2) that should latch those +/-1.65V rails might very well be RESET which is low. Even if you manually enable those +/-1.65V rails all micros might be in reset.
Those +/-1.65V rails seem like VACC for an ADC. So the other line might be the 3.3V digital for the chip. If that's missing, or RESET line is low, it might explain why you're getting nothing from the micro.
So RESET might be low because of a bad voltage supervisor chip / part of its circuit.
« Last Edit: December 21, 2022, 11:57:37 am by bob808 »
Offline thm_w
  • Non-expert
« Reply #4 on: December 21, 2022, 09:22:45 pm »
In the youtube comments, Dave verifies multiple hacked/missing/etc components on this meter.
Either production quality really slipped here, or someone did try to mess with it.
This would be one benefit of having a tamper sticker, not a "warranty void" one though.
Offline bob808
« Reply #5 on: December 21, 2022, 09:44:57 pm »
I assumed it's a new unit because it had the plastic foil on the display.
Offline SiliconWizard
« Reply #6 on: December 21, 2022, 10:10:58 pm »
If it got like this straight from production, this isn't pretty. I wouldn't expect something like this from Brymen. ::)
« Reply #7 on: December 21, 2022, 11:12:34 pm »
Yep, I cleaned it up and it's fine.
« Reply #8 on: December 21, 2022, 11:13:21 pm »
Yeah, very poor hand soldering.
Most likely replacing missing components from the PnP.
« Reply #9 on: December 21, 2022, 11:13:44 pm »
About 9 months old.
« Reply #10 on: December 21, 2022, 11:19:47 pm »
About 9 months old.
Oh you mean that it had worked for 9 months before failing?
« Reply #11 on: December 22, 2022, 04:08:49 am »
About 9 months old.
Yes, just died one day. Was working fine and then it didn't.
« Reply #12 on: December 22, 2022, 04:57:38 am »
Oh yeah. In this case, the bad touch-up in production may indeed have been the cause, and it wasn't caught during production tests - some soldering joint making intermittent short-circuit for instance, that ended up killing the microcontroller or something.
Some clients may ask to reject any non-functional boards after reflow and not accept rework altogether, but that would add significant production cost and would make the product much more expensive.
I don't even know if Brymen would accept that. And I guess your return rate is too low to be a concern (at least I hope so.)
« Reply #13 on: December 22, 2022, 05:21:33 am »
Correct. No concern on my part.
« Reply #14 on: December 22, 2022, 06:43:33 am »
LOL. EVERYONE including myself missed a major goof in this video. Can you spot it? It's not the fault, but it's something I was wrongly assuming. I can't believe not a single viewer picked me up on it!  :-DD
Offline armandine2
« Reply #15 on: December 22, 2022, 02:00:08 pm »
in for a penny - was the battery pack correctly loaded ?
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Online Kleinstein
« Reply #16 on: December 22, 2022, 04:23:55 pm »
Much of the test were to see if the µC runs and can be recognized from the debug / update interface.  If the µC is not running, chances are the LCD is not showing anything useful.
A suspect point could still be a power supply supervisor, if used. It may do more than enabling the supply to the µC, but it could also hold the µC in reset state.
The tricky point is that for the custom (could be just custom pin-out) µC it is not clear which pin actually is the reset input.
One may be more lucky with the LCD controller if this chip gets the same reset signal.
Offline floobydust
« Reply #17 on: December 24, 2022, 03:01:05 am »
Beuller Beuller I just watched the video and think U1 is the DMM IC, it's got all the analogs heading into it. U16 I'd say is the MCU. But then the crystal needs to feed both. I'd beep out the TX, RX programmer headers to confirm where they go.
OT fake Ferrari just auctioned off. I thought it was REAL!
« Reply #18 on: December 26, 2022, 10:00:30 am »
 :clap: You are the only one who noticed!
Someone on the live show also got it after I mentioned it and urged everyone to guess at it.
https://youtube.com/watch?v=oJbX-xcq0XU&si=EnSIkaIECMiOmarE&t=6738
Offline bob808
« Reply #19 on: December 26, 2022, 12:16:14 pm »
I was close, called the +/- 1.65V rails being for ADC.
Offline floobydust
« Reply #20 on: December 26, 2022, 10:30:23 pm »
Hey that's pretty funny. I'm just used to having no schematic, drawing out the circuit blocks in my mind, when doing repairs. Having a schematic is a luxury.
I find the best engineers in electronics have no need to be an "expert" or be right all of the time. So what, something wasn't right, just move on.
But there's this social push for "experts", know it all's- who are of course crap as designers, repair techs etc. The art constantly humbles a person.
The following users thanked this post: EEVblog
« Reply #21 on: December 26, 2022, 10:48:48 pm »
As I said in the video, most Youtubers would probably edit that out and forget it ever happened.
But I have no fear of being embarressed by a mistake made in the heat of filming.
Offline golden_labels
« Reply #22 on: December 27, 2022, 01:41:43 am »
Dave, you mentioned Brymen wouldn’t share schematics with you. I wonder: how much trouble would it cause to you, if someone from audience reverse-engineered the board and published the results?
People imagine AI as T1000. What we got so far is glorified T9.
« Reply #23 on: December 27, 2022, 03:21:16 am »
Zero trouble, go for it.
I've even done a video doing some on the BM235:
Offline bob808
« Reply #24 on: January 05, 2023, 04:59:07 pm »
So the micro was dead but also another IC? What could cause this? Overvoltage on 3.3V rail? Maybe the user tried hooking something up to the programming port and maybe used 5V instead of 3.3?
Will we get a part 3 where you go further?
