Hello,
Request for Youtube video on custom driver and controller for analog RGB LCD.
Like what was done in EEVblog #1055, EEVblog #1074, and EEVblog #1105.
I'm a Newbie with a box of LCD screens most are ### X 3 X ### (A-Si TFT active matrix).
Here is the datasheet of one: See attachment.
It is a 7", 480x3x234, A-Si, TFT, Active matrix, RGB stripe, white transmissive LCD.
I would like the video on how to design a custom driver and controller for the one attached, to learn what/how to for the others. So I can connect them to the GPIO on Arduino, Raspberry pi, and Beaglebone Black projects.
If I have this right, the "3" in "480x3x234" is for RGB. Which, from the datasheet, are analog. It has a 26-pin flat cable and a 2-pin power for backlight. Again if I have it right, the driver (discrete logic or FPGA) is between the LCD and the controller which is the interface to the GPIO on Microcontroller, computer or SBC. rignt?
If that could be done, I would be so grateful.
Thank You
