Author Topic: New OWON 14bit XDS3202A Oscilloscope  (Read 27980 times)
Offline fourtytwo42
  • Interested in all things green/ECO NOT political
Re: New OWON 14bit XDS3202A Oscilloscope
« Reply #50 on: May 31, 2017, 09:23:37 am »
It's good they have responded - and extra brownie points for doing it point-by-point.
I wonder how much will be changed - and how quickly?
I got a reply too regarding some firmware problems with a then new VDS1022I a year ago, since then silence and no new firmware so don't hold your breath on this one either!
Offline abraxa
  • Sigrok associate
« Reply #51 on: May 31, 2017, 09:47:35 am »
1. Package box shows 12-bits but actually 14-bits resolution on device label.
RE: Yes, it’s our package problem, we have start plan to change it.
To me, this reads as if they initially only were doing 12-bit interpolation but someone said "if we can turn 8 bit ADC data into 12 bit, can't we also do 14 bit?", so the specs (and software) were changed but the device packaging was overlooked.
12 bit makes a difference in the noise level. It is one of the very few high resolution scopes and is a great deal at around $450 compared with a comparable data acquisition card.
If you get true 12 bit, sure. But I wouldn't trust this kind of company to either use a real 12-bit ADC or perform the required amount of oversampling to approximate them with an 8-bit ADC. Sure, the scope says it uses 12-bit values (and probably shows them as such) but how accurate are they?
It's even worse when claiming 14 bits of resolution when using an 8-bit ADC and not doing the required oversampling, which they are:
10. Single channel on 14-bit resolution, sample rates at 100MS/s.
RE: Yes, so it does. Limited by hardware, we could implement 1GS/s sample rate only at 8-bits mode.
So in essence, they use an 1GS/s 8-bit ADC and claim they can deliver 14 bits of resolution when performing 10x oversampling. However, that would only yield 1.5 additional bits, so they're lying. For an additional 6 bits of resolution, they'd have to perform 4096x oversampling. Quite the difference, I'd say.
« Last Edit: May 31, 2017, 09:49:08 am by abraxa »
Offline StillTrying
  • Country: Broken Britain
« Reply #52 on: May 31, 2017, 11:06:54 am »
"3 We are still testing on how to hold the thin device body without losing stability like to expand stool size."
They're going to fill it up with what ? :o  Perhaps they could just release a much heavier version of the firmware.
"9. Slow response for touch screen
RE: It’s a main issue for various oscilloscope manufacturer to study how to improve touch screen experience these years."
Yep, it doesn't matter if the UI doesn't work properly, it's not as if the user is trying to concentrate on something else while they're using it.
Send it back.
And they should really make the samplerates and resolutions more clear. Currently it is completely misleading:
All the 'affordable' LOL, scope manufacturers are the same.
« Last Edit: May 31, 2017, 11:08:31 am by StillTrying »
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #53 on: May 31, 2017, 05:23:28 pm »
The issue is not so much the obvious problems, but the fact that they needed someone else to tell them.
Day Job: Mostly LEDs
Online nctnico
« Reply #54 on: May 31, 2017, 07:00:33 pm »
That doesn't have to be the case. There are ADCs out there which offer higher resolution at lower speeds. Dave should do a teardown to see what is inside!
The following users thanked this post: thm_w, Fungus
Online EEVblog
« Reply #55 on: May 31, 2017, 11:37:26 pm »
No, I'm pretty sure they are using the Hittite HMCAD1520, a switchable 8/12/14 bit converter
http://www.analog.com/media/en/technical-documentation/data-sheets/hmcad1520.pdf
The sample rate and bit specs match this chip precisely.
Online EEVblog
« Reply #56 on: May 31, 2017, 11:39:31 pm »
Indeed.
And all those issues were found with me doing a single take 30 minute first impression straight out of the box playing around with no prep or test plan.
Trivial stuff.
Offline Brumby
« Reply #57 on: June 01, 2017, 01:14:42 am »
I'm not arguing that - I'm just saying that it was nice to get a detailed response.
The real question I have is why the heck they would send out such a unit in this state?  From their response to Dave, it would seem they were aware of a couple of the issues - issues that one would not expect to see in a product brought to market.
I get the feeling that they sent Dave a prototype for him to pick it apart and tell them what they need to change for it to become a better candidate for commercial release.  The free EEVblog consultancy, as it were.  However, I feel that there would be a lot more on the list if Dave sat down and did a solid review.
I wonder what else Dave might receive further down the track?
« Last Edit: June 01, 2017, 01:17:47 am by Brumby »
Online EEVblog
« Reply #58 on: June 01, 2017, 10:51:38 am »
It's for sale:
http://www.batronix.com/shop/oscilloscopes/Owon-XDS3202A.html
https://www.amazon.com/OWON-XDS3202A-Multi-Touch-Oscilloscope-resolution/dp/B01MXVNMFB
http://www.ebay.com/itm/OWON-XDS-XDS3202A-Measurement-200Mhz-1G-Storage-Oscilloscope-12-bits-ADC-40M-re-/222237318097
Offline sibeen
« Reply #59 on: June 01, 2017, 01:40:17 pm »
It's for sale:
Jeez, Dave. Should you really have put it on ebay?
Online thm_w
  • Non-expert
« Reply #60 on: June 01, 2017, 07:53:07 pm »
$83/ea, not that bad. Surprised not many scopes have used it, it was released back in 2013.
Pico 5000 series has it (https://www.eevblog.com/forum/blog/eevblog-521-picoscope-5000-usb-oscilloscope-teardown/), retail is $1,000 USD, release 2013.
HMCAD1511 is in your 1054z and $46/ea.
Offline Brumby
« Reply #61 on: June 02, 2017, 06:40:53 am »
It's for sale:
Oh dear.
Wonder what Rev 2 will be like?
Offline abraxa
  • Sigrok associate
« Reply #62 on: June 02, 2017, 06:50:25 am »
Interesting, I didn't know such ADCs existed. I take back the liar then and stand corrected.
Offline BU508ATopic starter
« Reply #63 on: June 02, 2017, 09:15:04 pm »
You'll never know. And that is one of the reasons, I do not trust at all this kind of gear.
Offline patrik96
  • Country: hu
« Reply #64 on: April 15, 2023, 07:28:55 am »
HI, May someone could help,
I have a XDS3202 (14bit) scope, unfortuneately the GND aligator clips uncained and touch -70V rail, and after my scope semi brick,
It mean the screen, and all fuction working except no visualable signal on the screen, (either the AWG not work) If I put direct input on the ADC IC it has visuable signal,
My investigation is may the minus -xxV power suply faild but no schematic found it.
The new main panel is almost 800€ what is not a option
A schematic could help
« Last Edit: April 15, 2023, 03:24:47 pm by patrik96 »
