Author Topic: EEVblog #982 - HP54616B 500MHz Oscilloscope REPAIR  (Read 25041 times)
Offline onlyrgu
  • Engineer by Nature!!
Re: EEVblog #982 - HP54616B 500MHz Oscilloscope REPAIR
« Reply #50 on: April 14, 2017, 04:56:35 pm »
Yes It look fixable, Everything is!!
I think the Hybrid module is fixable!!
1.align the hybrid module
2. use a sticky(non-conductive) tape on other side of the hybrid module and secure it
3. scrape the trace and solder the connections.(similar to what you did on the front panel
4. use 2 element glue to fix the rest of the crack,
might save the module and your 45$ + shipping
thanks for the video
Offline harrimansat
Offline ZsHorvath
« Reply #52 on: July 10, 2022, 08:35:40 pm »
Hi All,
I've just purchased a similar scope.
I saw at 29 minutes in the video Dave has mentioned the CLIP at Keysight.
I tried to find the same download ("54600A and 54601A Component Level Information Package") but it appears to be removed. Does anyone know if it is available somewhere else or has a copy?
Thanks!
Offline MarkL
« Reply #53 on: July 12, 2022, 03:39:23 pm »
The only CLIP I know of for this scope was called "546XXA_CLIP_Package.zip".  You can search around for it, or take a look here:
  https://xdevs.com/doc/HP_Agilent_Keysight/54600/
The "54600 schematics/" directory contains all the files from the zip archive.
