Author Topic: EEVblog 1456 - Sega Toys Homestar Planetarium REPAIR  (Read 4463 times)
Offline EEVblogTopic starter
« on: February 11, 2022, 09:44:17 pm »
Repairing a Sega Toys Deathstar, err, Homestar Flux Planetarium
https://amzn.to/3BsaIH7
The designer Takayuki Ohira talking about the design:
10 minutes of the Casio FX-91W spinning:
Offline Fungus
Re: EEVblog 1456 - Sega Toys Homestar Planetarium REPAIR
« Reply #1 on: February 12, 2022, 01:34:04 pm »
Is it just me or is the motor a bit jerky?
Offline jonovid
    • JONOVID
« Reply #2 on: February 13, 2022, 03:36:48 am »
Why drive belts are used is to reduce motor noise in tape recorders & vinyl belt drive turntables at higher revolutions per minute RPM's at the motor axle.
plastic spur gears also transmit tooth noise, however at the lower RPM's plastic gears will do as the gear tooth noise is below the lower limit of human audibility.
plastic gear grease is also used reduce gear tooth noise, as well as lubrication.
Hobbyist with a basic knowledge of electronics
