Author Topic: EEVblog 1434 - Cadex C7000 Battery Analyser Teardown  (Read 3570 times)
Offline EEVblogTopic starter
« on: November 03, 2021, 11:22:07 pm »
Teardown of a Cadex C7000 battery analyser.
The following users thanked this post: SeanB, thm_w, faraday
Offline thm_w
  • Non-expert
Re: EEVblog 1434 - Cadex C7000 Battery Analyser Teardown
« Reply #1 on: November 04, 2021, 04:37:04 am »
Dave, curious where this came from, since you said it was 110V I assume it was shipped from NA?
They still list the C7000 on their website: https://www.cadex.com/products
« Reply #2 on: November 04, 2021, 08:22:16 am »
Yes, US import.
Offline TheSteve
  • Living the Dream
« Reply #3 on: November 04, 2021, 04:38:44 pm »
Back in the 90's all of the serious cellular phone shops in my area had a Cadex unit to test batteries. They were pretty useful, especially in the NiCAD and NiMH days. They were also quite common in the 2-way radio rental and service dealers.
VE7FM
Offline Kleinstein
« Reply #4 on: November 04, 2021, 05:04:56 pm »
Chances are there is a 10 bit ADC inside the PIC.
Offline Twoflower
« Reply #5 on: November 04, 2021, 07:04:38 pm »
Nice label there.  :-DD
Offline hli
« Reply #6 on: November 04, 2021, 07:51:40 pm »
Just a guess: 4 of the resistors are used as load for discharging, and the remaining 3 are used during charging, to balance multi-level cells.
Offline markus
  • Country: ee
« Reply #7 on: November 04, 2021, 08:23:40 pm »
Set a C7000 battery analyzer for stand-alone use
1 Press the MENU key on the C7000 battery analyzer.
2 Press ▲ or ▼ to scroll to SYSTEM SETUP (on the analyzer display screen), and then press ENTER.
3 Press ▲ or ▼ to scroll to OUTPUT DEVICES, and then press ENTER.
4 Press ▲ or ▼ to scroll to SERIAL PORT DEVICE, and then press ENTER.
5 Press ▲ or ▼ to scroll to any setting other than BATSHOP, and then press ENTER.
6 Press ENTER again to confirm your selection.
7 Press ESC twice to return to the global display.
The latest C7000 firmware V3.53 can be found here http://www.ko4bb.com/getsimple/index.php?id=download&file=06_Misc_Test_Equipment/Cadex_C7000_Battery_Analyzer_EPROM_3.53.BIN
« Last Edit: November 05, 2021, 05:41:07 pm by markus »
The following users thanked this post: faraday
Offline faraday
    • ielektro.net
« Reply #8 on: November 10, 2021, 11:50:07 am »
I have newer version c7400-c,  need firmware 3.xx does anybody have?
« Last Edit: November 23, 2021, 04:23:02 am by faraday »
