Author Topic: EEVblog 1392 - No temp probe? No problem!  (Read 3172 times)
Online EEVblogTopic starter
« on: May 12, 2021, 02:04:59 pm »
Think your multimeter doesn't have inbuilt temperature measurement? Think again!
Dave shows you a trick to measure ambient temperature with your multimeter without a temperature probe.
Followup video testing in the fridge:
Offline Wiljan
Re: EEVblog 1392 - No temp probe? No problem!
« Reply #1 on: May 14, 2021, 03:42:47 pm »
I have a Keysight U1282A here, the display shows 18.4 deg for the meter internal.
If I select the Temp mode for ext probe and short the test lead ... it shows 18.4 just as you explained  :D
So my question: Can an external probe show lower than the room temperature?
I mean this is 0 ohm when leads are shorted so it will be hard to get a negative ohm
Online gamalot
  • Correct my English
    • Youtube
« Reply #2 on: May 14, 2021, 03:46:52 pm »
When using a thermocouple to measure temperature, it measures voltage instead of resistance.
https://en.wikipedia.org/wiki/Thermocouple
Offline David Hess
  • DavidH
« Reply #3 on: May 14, 2021, 04:31:31 pm »
My Tektronix multimeter has a dual display which shows the cold junction temperature as well as the thermocouple probe temperature.
