Author Topic: EEVblog #1367 - 5 Types of Oscilloscope Passive Probes COMPARED  (Read 18090 times)
Offline tggzzz
Re: EEVblog #1367 - 5 Types of Oscilloscope Passive Probes COMPARED
« Reply #75 on: February 01, 2021, 02:14:14 pm »
I did some testing with the Lecroy 7300A but didn't got much wiser. First of all it turns out my Mini-circuits directional coupler is broken and the other one I have is a cheap one from Ebay with only goes to 200MHz. With the latter the SWR line (using Anritsu MS4630B network analyser) isn't flat (from 1.00 @30MHz to 1.05 @200MHz) when connected to the 7300A's input. But I get the same result with the R&S RTB3004.
I get exactly the same trace on both the Lecroy 7300A and the R&S RTB3004 in 50 Ohm mode using two different generators. A 12dB inline attenuator doesn't change the signal shape at all on the Lecroy 7300A.
All in all nothing conclusive yet.
I did some further investigation. It seems that the problem is not the oscilloscope input but the interaction between the signal source and the probe itself. If I put an attenuator or 50 Ohm feed-through between the Lecroy 7300A calibrator output and the probe the signal improves.
More likely "In that case the effect you see without the source 50ohm might be due to the cal out behaving properly when correctly loaded."
But isn't the whole point of probing to see the signal as it is as much as possible? Requiring a signal to be 'correctly loaded' is not always possible or even desireable (think about the good old PCI bus for example as an unterminated high speed bus).
Yes, and in your experiment you were seeing the signal correctly when it didn't have the 50ohm termination. It is just that the source's output was different when not loaded with 50ohms.
Here's the Tek 485's cal out when driving 1Mohm//20pF via a 2m lead. The timebase is 100ns/div. Not exactly a 1ns risetime - or rather each step is 1ns risetime :)
The point is to measure the signal in normal operation without disturbing it. If the signal is meant to be unterminated (e.g. a PCI bus), then of course you wouldn't terminate it because that wouldn't reflect (ho ho) normal operation.
Online nctnico
« Reply #76 on: February 01, 2021, 02:58:58 pm »
No. In my experiment I terminated both ends of the coax of the Z0 probe which gave me the correct signal shape. I didn't load the calibrator output. I'll try to do some more modelling when I have the time.
Offline tggzzz
« Reply #77 on: February 01, 2021, 06:17:59 pm »
I really do wish you would provide a schematic or photo. That would enable us (and probably you) to understand what is happening.
If you have had a 50ohm termination between the 1kohm resistor and the 50ohm coax (in addition to at the scope end), then that is clearly an incorrectly implemented Z0 probe.
What does the manual say the cal out load should be when measuring fast risetimes (it won't matter for the 10kHz low frequency probe calibration)?
